-   -   Cam info (http://www.hotrodders.com/forum/cam-info-215870.html)
Thumper33 03-02-2012 01:14 PM
Cam info
Why do they reverse grind or custom grind cams do they work as well as a regular one.
I have a comp cam the lift is 488/465 in a 383 stroker.
Thanks Thumper 33
hpete 03-02-2012 01:33 PM
They reverse grind them so that you can use a two gear drive rather than a chain or idler gear. It's a good idea but overkill for most street cars. A custom grind is exactly that you call the camgrinder and give him your specs and he grinds it to order. Great if you know what your doing otherwise...
techinspector1 03-02-2012 02:02 PM
You might have a two-motor marine application also, where you want one of the motors to turn counter-clockwise. That would also require grinding the cam in reverse.
68NovaSS 03-03-2012 07:56 AM
Please don't double post, you posted this thread twice, only hours apart, there were no responses, it has been deleted. Please read the board guidelines.
