Cam info - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2012, 01:14 PM
Cam info
Why do they reverse grind or custom grind cams do they work as well as a regular one.
I have a comp cam the lift is 488/465 in a 383 stroker.
Thanks Thumper 33
Old 03-02-2012, 01:33 PM
They reverse grind them so that you can use a two gear drive rather than a chain or idler gear. It's a good idea but overkill for most street cars. A custom grind is exactly that you call the camgrinder and give him your specs and he grinds it to order. Great if you know what your doing otherwise...
Old 03-02-2012, 02:02 PM
techinspector1's Avatar
Wiki Edits: 326
You might have a two-motor marine application also, where you want one of the motors to turn counter-clockwise. That would also require grinding the cam in reverse.
Old 03-03-2012, 07:56 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Please don't double post, you posted this thread twice, only hours apart, there were no responses, it has been deleted. Please read the board guidelines.
Semper Fi
info on man-a-fre rick1932 Engine 3 12-07-2011 12:32 PM
need cam info please. durand322 Engine 4 03-03-2010 11:10 AM
please help i need info on a pontaic carburator 455, no info online! COUGARPOWER Engine 7 09-14-2009 12:45 AM
Info gdxroll Introduce Yourself 1 05-26-2009 06:03 AM
Custom intake tube info (Cavalier, but good info for all) TheVis Engine 11 02-09-2007 04:44 AM
