Al, the key on the crank should be at approx. the 2 o'clock position when lined up correctly. Check the crank gear carefully, some of the markings on the gears are very small or it might be a triangle or small rectangular shape. When the mark on the cam gear is at 6 o'clock and the mark on the crank gear is at 12 o'clock, the engine will be at TDC of the compression stroke on # 6 cyl. This is the correct alignment.
I hope this helps. |
Correct. When the cam and crank are aligned correctly, dots at 6 and 12 respectively, the dist. rotor will be pointing to fire # 6 on the compression stroke.
You're welcome.
| cam base circle vs. lobe lift question | S10xGN | Engine | 4 | 09-19-2004 10:31 AM |
| Installed New Cam, CAR WONT Start/no Compression? | sum87mustang | Engine | 4 | 10-27-2003 07:52 AM |
| solid roller cam...lifter broke! | chevyelc81 | Engine | 7 | 09-05-2003 01:41 AM |
| 289 cam change | franklin289 | Engine | 0 | 04-22-2003 02:38 PM |
| Installing a cam | 70 nova | Engine | 10 | 03-30-2003 03:13 AM |
