cam installed, car turns over but wont crank. - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-08-2012, 11:11 AM
What's up I have a lil problem here, I installed a new cam into the car along, with new sprocket and timing chain, tryed to start the car and the car turns over but won't crank, also while turning over the carburator sounds like its missing and throws like a little mist. Also the dizzy was removed and set the rotor to face the 5 o'clock position which is aiming towards the #1 cylinder, #1 cylinder is at TDC , I put like a plastic looking nail into spark plug hole and the piston pushed the nail all the way up upto where it was tight to get out...also rechecked spark plug wires and battery and all the valve are good fit, not too tight or loose.
Help what do I do???
Old 07-08-2012, 11:25 AM
Ok is it a chevy, or Dodge? if so did you put the dots together on the chain gears if so ti is 180 deg out pull no.1 plug put your finger over the hole and have someone bump the motor over after the compression blows your finger seal turn your crank back to 0 and restab your distributor
Old 07-08-2012, 12:50 PM
T-bucket23's Avatar
Wiki Edits: 26
You have a lot of potential issues.
Did you line up the timing dots on the timing gears , cam at 6O clock and crank at 12
How did you set the valves
When you dropped in the distributor was #1 on TDC "FIRING STROKE". ( if you lined up the dots as above and dropped in the distributor the engine was at TDC on #6 not on #1. This is a common mistake. Re validate tdc on # 1, both valves should be closed.
Chet
Old 07-08-2012, 03:43 PM
Irelands child's Avatar
Timing chain installed wrong? Dots not correctly aligned?
Dist. in wrong?
Valve lifters have too much preload, i.e. rockers adjusted too tight?
What's the engine? Marks on timing gears for Ford and Chevy are different MoPar, I believe is the same as Ford
Irelands child
Old 07-08-2012, 05:11 PM
okay it a chevy 350 4 bolt main, lined up dot to dot then turned 180 so it would be 12-12 also first cylinder was at TDC I put a plastic nail, and felt the air come out and it ddrove the nail all the way too the top correct right,
What do you mean put finger in spark whole bring to top dead center then bring it back alittle, won't that bring the piston back down a little
Old 07-08-2012, 06:43 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
I'm confused, you lined up the dots, dot to dot so that would be 12 on the crank and 6 cam. Then you rotated it 180? That would have moved the dots to 6 crank, 12 cam, and would also have moved the piston away from TDC, but not make any difference if it was installed dot to dot, it is what you installed it at...what am I missing here?
Semper Fi
Old 07-08-2012, 07:59 PM
I said that I installed it dot to dot (cam 6 crank 12) then I installed the chain, then I turned over the motor so that the crank is at 12 and cam at 12 and lined up the rotor to #1 that's what I don't understand why it won't turn on
Old 07-08-2012, 08:12 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
If you are sure that the firing order is right (1-8-4-3-6-5-7-2) and #1 is correct, I would loosen all of the rockers until you get it to start then adjust them with it running. It sounds like you may have them too tight.
Old 07-08-2012, 08:36 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Here's what you said:
[QUOTE=kingofny1997;1571967]... lined up dot to dot then turned 180 so it would be 12-12 also first cylinder was at TDC [QUOTE]
I'm assuming you did it your way for easier dot alignment?
Semper Fi
Old 07-09-2012, 11:35 AM
What do you mean, I lined it up cam 6o'clock and crank 12, but if I install the dizzy in it will be firing at #6 cyl , so you have to bring the cam to 12 o'clock and crank at 12o'clock so that now its TDC, I know its the timing has to be off somewhere, because first start was back firing threw carburator and then a little adjustment it stopped the backfiring but still wouldn't turn on, so I have to take the spark plugs out and turn the motor over by hand, and try to keep lining it up till the exact dot but it hard since the timing cover it on, so I put my finger in the #1 spark plug and when the air is completly gone then install distributor and everything else for the crank on
Old 07-09-2012, 01:26 PM
T-bucket23's Avatar
Wiki Edits: 26
Put your finger over the #1 plug hole and have someone bump the key until you start to feel it push your finger out. Turn it by hand to bring up the timing mark and check the distributor at that point.
It is very difficult to feel the compression if you are turning it by hand.
The other option is to pull the valve cover and watch the valves, when you see the intake open and close it will be coming up to TDC compression. Turn it by hand up to the timing mark and check the distributor.
Chet
Old 07-09-2012, 02:21 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Both valves closed, #1 piston at TDC, dots lined up correctly and if you need to, with a long screwdriver, turn the oil pump rod to relocate the slot so the dist is sitting where you want it to be when it drops in, pointing at #1 terminal. If you need to, move it one tooth either way. The dist doesn't care where it's sitting as long as it's pointing at #1 when it's ready to fire. Whatever position you put the dist in, leave enough room to turn it to set timing once it stars. I suspect you're 180 degrees out.
Semper Fi
Old 07-09-2012, 05:10 PM
180 degrees out meaning cam is 6o'clock and Crank at 12
Old 07-09-2012, 05:42 PM
S10 Racer's Avatar
You need to rotate the crank until both crank & cam dots are at 12:00. That is #1 TDC. You still need to check with your finger in the #1 plug hole whether it is the compression stroke or the exhaust stroke because each piston is at TDC twice during a cycle. You want the compression stroke.
Old 07-09-2012, 06:22 PM
when the compression hits and blows the seal you make with your finger it is not going to stop exactly on 0 it is still going to go a little past the mark just turn the mark back to 0 and restab your distributor and it should fire up
V6 -V8 swap Car wont crank CHEVY94-00 Engine 18 08-29-2011 02:44 PM
installed starter, turns over but will start Huskie007 Electrical 1 04-09-2011 06:56 PM
Car Turns Over But Wont Start DTL504 Engine 19 12-27-2009 07:58 AM
Car Wont Crank ponybuster Engine 13 11-28-2003 06:12 AM
Installed New Cam, CAR WONT Start/no Compression? sum87mustang Engine 4 10-27-2003 07:52 AM
