Cam/Intake combo 283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-20-2013, 04:40 PM
I'm building a 283 for my '57 chevy short bed to tow my Travel Trailer. I got a set of Vortec heads and had them shaved .030 to up my compression. What lift /duration cam and intake would you suggest?
Old 03-20-2013, 07:18 PM
I'd stay fairly mild. Most every cam vendor has a cam that's going to be around 204 intake @ .050" 214 exhaust @ .050" and 112* sep. I've had good luck with the bargan brand cams of this nature( elgin, melling, wolverine, ect). I've had great result with this size of cam in a small motor and it behaves as well as a stock cam.
Old 03-20-2013, 08:15 PM
Cam lift w/ Vortec heads
I've gathered that with vortec heads you don't need a lot of lift what would you suggest? Also, what intake?
Old 03-20-2013, 08:44 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Maybe pick the cam later. 30 off of the heads is allot. figure the compression ratio then the trans type and the gears.
what is the finall cc of those milled heads? some start as 64cc some start as 67cc, what tis the casting number.
is the block stock or rebuilt. the 283 goes back a long ways, just consider what your putting the heads on, figure the specs into the head cc volume to find compression ratio
then think cam but dont talk cam till you know the compression target, trans, gear and tire.
TJ
Old 03-20-2013, 09:11 PM
BOBCRMAN@aol.com's Avatar
Better put a real big radiator in that vehicle and never get it hot. .030" off a Vortec head is dangerous. The decks are thin to start with . Now you will have questionable head gasket seal and an intake alignment/seal issue.
Old 03-20-2013, 09:39 PM
Basically you are going to have to choose your cam by the duration ad live with what ever the lift ends up being. You say it's a 283 and you're going to tow with it. If you go much larger duration it's not going to be able to to pull your hat off your head. For towing you want your torque to be there right off idle. Sure there are still plenty of big cammed high reving 283's out there but you would not be happy with them pulling a trailer. As far as that goes I would take a bone stock 350 to a big cam 283. I hope your trailer fairly light.
When you figure in cost of parts and bang for your buck I'd put together a 350 with the same cam specs I gave you unless your plan is to an original motor in the truck.
Old 03-20-2013, 10:34 PM
Custom10's Avatar
Just for the fun of it,,,
Here is a great way to use (if so equiped) your old wire loom stands from a 4 bolt perimeter type valve cover when you swap to vortec. Dont thow out your old chrome posts, just hammer em flat and use the bolt holes on the votec head to secure, a bit of fiddling around while you figure out the cam
You can also see the bolt in the post with the old elongated valve cover washer, this helps pin down the header flange
Old 03-20-2013, 11:13 PM
spinn's Avatar
I think it is pretty standard. Does somebody go around cracking all your vortec heads, or something.
I got mine from a T-bone accident in town. It was totaled. I asked if he would buy it back and sell me the engine/heads. He would have sold me the whole vortec 350 for $450. Nothing special, milled the chambers down to 60cc. That is over .040" off. No problems. I did not upgrade to screw in studs. I am waiting for them to pull out like I was told they would. Whens it going to happen?
My vortec build is also supercharged at almost 10psi. It uses the performer cam, and ls6 springs.
Depending on what you are doing, it is possible you will not want to use even the performer cam. It will soften the low end dynamic enough to notice, depending on gear and stall.
Old 03-21-2013, 10:54 AM
Compression
Thanks for all the input. Does anyone know what the compression is going to be on this 283 with flat top pistons, the heads are down to about 57 or 58cc near as I can figure (062 head with .030 off)?
283 sbc vortec rv cam
Cam and intake manifold combo question. Dajerseyrat Engine 5 03-24-2011 03:05 PM
intake and cam combo? cope Engine 4 05-04-2008 08:50 PM
head,cam,intake combo Goobert Engine 4 04-03-2008 12:00 AM
what cam/intake combo, rebuilding chevy 350 30 over 73camaro Engine 2 08-02-2006 01:22 PM
Your opinions on intake, carb, and cam combo SkyMan9600 Engine 6 02-19-2005 11:38 PM
