I put a edelbrock performer intake and a 465 lift 224 duration . That 's the cam with a stock convertor. If you don't use that cam dont go over 470 lift . It's will have a little loppy Idle. . Go with 600 Double pumber . You can get that cam and lifter from summit racing. It's a summit brand for about 85$ . Make that 305 run good. 70 Nova.
Look a your cam bearing. If they look good .It will be ok But put that cam in slow and easy. You should have good oil pressure. but you need a stall a 1,900 would work fine for you . You can find them for under 200$ just look around.
