Cam Lift question Please - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-26-2010, 11:19 AM
I am not up on exactly how designs work on cams.
I understand the duration and lift etc..but when it comes to
picking and or having one cut for you seems like a shot in the dark.
My question is what or why would the cam lift on exhaust be higher
than the cam lift on the intake? I have a cam I am hoping will work good
and the desk top dyno numbers look impressive. Usually the exhaust lift is
the same or less than the intake lift. My cam lift(s)is .578 int .608 exh
Can someone explain to me the benifit of having the exhaust valve stay
open longer? Doesn't that encroach into the lift of the next intake???
Thanks for the advise.
Old 08-26-2010, 11:47 AM
DoubleVision's Avatar
While there will be different views on this that`s what it`s all about.
Let`s take the first example, the small block chevy, most stock SBC heads have pretty much the same exhaust port which is short and with a good shape, in stock form it`s efficient. The intake side is not so great without work. I only use dual pattern cams in SBC`s when the exhaust system isn`t as good as it could be. If the system is going to be free flowing and opened up I use a single pattern. Next example, Small block Ford, in stock form the exhaust ports are absolutely horrible, kinked and small, so any help the cam can give the exhaust side is of benefit. If you want to get into technical details of it, go to any big cam company`s web site, comp cams, isky, or just do a general web search on dual pattern cams. I`ve seen some say that what I said about sbc heads isn`t true that the exhaust isn`t so good and the intake is great, however, myself or others I`ve raced with never did much work to a exhaust port simply because it wasn`t needed.
Old 08-26-2010, 11:49 AM
my87Z's Avatar
Veteran/Firefighter-Paramedic
you have what are called single pattern cams and dual pattern cams. a single pattern cam will have the same duration and lift on both the intake and exhuast lobes ie; 270/270 220/220 .470/.470" a single pattern cam works well with a motor that has a good set of heads on it, ones with good flowing exhuast ports as well as a car that has a free flowing exhaust. then you have the dual pattern cams, ones with a higher duration and or lift on one lobe or the other. typically you will find that most dual pattern cams come with more duration and lift on the exhaust side simply because with the intake valve being larger it will allow more fuel in than the exhuast valve can let out in the same amount of time. dual patterns are a rather old technology and were produced because not that many people were using aftermarket heads on their motors but using production heads such as the double/camel hump heads which have restrictive exhaust ports and therefor need the cam to open the exhaust valve open more and longer. but now-a-days with more and more people using aftermarket heads there really is no benifit to the dual pattern cam ecept for the fact that it may raise your curve up slightly and creat a touch more peak hp/tq.
since most cams out today still use the dual pattern design you could do something like what i did where i offset the dual pattern by using a larger rocker arm (1.6) on the intake and the stock size (1.5) on the exhaust. but when using any production heads i would still use the dual pattern and take advantage of the extra lift and duration on the exhaust but with most aftermarket heads it is obsolite
Old 08-26-2010, 11:59 AM
Dual Pattern Cam Answers-Thanks
My cam is the Isky 396284/294 hyd roller, 578int lift, 608 exh lift
I have the old 3964291 LS6 rect port heads with 2.19/1.88 valves.
Was wondering how this thing is going to respond and of course how she will sound. My buddy's desk top dyno software says with my setup she'll
be 539hp @ 5500 7 565tq @ 4000
Oh I have a 454 +.060, SRP 141636 w/-14 dome, 108.9cc heads to the best
of my knowledge I will be right on or around 9.7 depending on which head
gasket I go with for thickness.
Commets please?
Old 08-26-2010, 12:05 PM
my87Z's Avatar
Commets please?
no,no,no the headgasket thicknesses shouldn't vary that much. you want your "in the hole" (piston @TDC to deck) clearance + your deck to head clearnace (called quench) to be at an optimal .039-.045" so if you are in the hole by .015" then you should be looking for a .030" headgasket, dont go messing with the quench as you will be messing with detonation
Old 08-26-2010, 12:13 PM
my87Z's Avatar
those heads with some minor port, bowl, valve work, 9.7:1 CR, that cam, and a decent dual plane intake and 850cfm DP on a 468cid should produce atleast 550/550 i think the sim may be a bit conservitive. you have to remember that those heads were on a 454 back in 70-71' that "produced" 450hp and most all would say that it was a very conservitive estimation. most belived it to be over 500hp
my87Z..thanks more please
The old pistons were .045 in the hole. this was out
of a reman AC Delco 454 +.030 engine. I was told that is
typical for GM's stock pistons to be .045 +/-. These SRP
#141636 forged alum I've been told are like others like KB's
in that they are .020-.025 in the hole. I was going to have the block
decked but chose not to due to wanted to run pump gas..BUT!!
want to be 9.5-9.7. No way of knowing I guess how much in the hole
the new pistons will be until she is together. Unless you know???
Old 08-26-2010, 12:16 PM
my87Z's Avatar
no, the only true way is to measure when it it all together. in my opinion you shouldn't even buy your head gaskets until you have measured, never by them blindly. and never buy "all inclusive" gasket kit's as they will typically set your quench through the roof.
Old 08-26-2010, 12:27 PM
my87Z & doublevision THANKS.more please
I have not purchased head gaskt yet and won't till the very end.
After she is together (short block) my only way to get more out of
it if the pistons are more than .015-.020 is to shave the heads or
reduce head gasket thickness. I really do not want to mill the heads
as I am basing my calcs on Mortec and other site for the "cc" measurement
on the 291 which come up as 108.9. Which who knows if that is correct
and/or if they have been mill already in the past.
Old 08-26-2010, 12:38 PM
my87Z's Avatar
do search for cc'ing heads it can be done in your backyard with about 10-15.00 of drugstore supplies and a CD or peice of plexi glass. and you really dont want to reduce the headgasket thinkness more than .005" one way or the other so that you maintain the quench that i mentioned. this is very important. while you are searching this site you should also look up the work quench. it is not something to be minipulated by much and certainly not to gain a quarter point of compression
Old 08-26-2010, 12:52 PM
my87Z...again..thanks
I will remember that bit of good info on the quench.
"you want quench to be right on or dam close to .045..!!"
and quench equals "in the hole plus gasket thickness"
Old 08-26-2010, 01:40 PM
Since you have the pistons, and apparently don't want to deck the block, assemble the short block, measure the "in the hole distance", plan a gasket to yield .045 quench, and adjust (mill) the heads to produce your desired CR. Unless you find that you are so far down in that you need to mill the block (or replace pistons) to get to .045. Then, you're looking at a tear down anyway.
Old 08-26-2010, 02:08 PM
engineczar's Avatar
Getting back to the original question. Picking whether or not a cam uses a dual pattern or single pattern lobe and or higher lifts on the intake or exhaust side is in many cases a function of the intake/exhaust port flow ratio. While there's no magic ratio number most stock type heads flow somewhere around 65%-70% with the exhaust flowing about 70% of the intake. A lower ratio usually dictates a weaker exhaust port which is helped with more duration/lift/rocker ratio, and consequently a ratio above 70% might require less to prevent over scavenging.
BSE Racing Engines
Old 08-26-2010, 02:51 PM
engineczar..thanks one more ? please
with the 291 rect port heads I have and knowing what the
ports are in them, "in your opinion is the dual pattern cam I have the
optimum choice"? or should I sell it and buy a single pattern
with say .600/.600 with a 246/256 dur on a 110 or 108 LS?
I kind of like the numbers on the one I have..I am more concern with
go power than sound power, but would like her to sound nasty as hell
as a secondary bennie.
Thoughts?
Old 08-26-2010, 03:17 PM
engineczar's Avatar
Those heads in stock form are in the 71% I/E range. If I didn't already have a cam and had to pick one I would probably look at a single pattern cam to start. Those heads are pretty lazy at low RPM's due to how big the ports are. In your case I'm not sure you'd see any big changes going from your current cam to something else until the RPM's get up there. What sort of compression ratio do you have and what's it going in to? and what do you have for an exhaust?
BSE Racing Engines
327 cam question... Jim Rockford Engine 9 10-26-2009 06:57 PM
Timing chain/ Cam reusing question Biscuit6447 Engine 19 10-23-2009 07:22 AM
Cam Question pena0724 Engine 13 03-07-2009 06:59 AM
Anybody dealt with this guy on ebay? Or through Dirttrackthunder.com? killerformula Hotrodders' Lounge 20 08-31-2008 06:12 PM
A question about dual lift profile engines. dmc12mk3 Engine 8 06-16-2004 11:31 PM
