Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam/lifter break in Oil
Old 07-10-2012, 01:19 PM
S10 Racer's Avatar
S10 Racer S10 Racer is offline
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
Break-in oil is different from assembly lube, you need both. I use Valvoline VR-1 without any additives and have had no problems. I changed it after a few hours at the track. Joe Gibb & Brad Penn oils are a couple of well known suppliers of break in oil w/zinc. Just not sure if it's available where you are. Any conventional oil with a content of 1100ppm or more of zinc will work. DO NOT use a synthetic for break in.
The Following User Says Thank You to S10 Racer For This Useful Post:
27TRoadsterguy (07-10-2012)
