Cam/lifter break in Oil - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-11-2012, 04:28 PM
6426yy's Avatar
No one else has mentioned this yet but I always use a set of old worn out valve springs when doing a cam breakin also.
  #17 (permalink)
Old 07-11-2012, 09:09 PM
27TRoadsterguy's Avatar
Last journal entry: Frame Basics
Well I went to see the owner of the Home hardware in Stamford plaza(a friend of mine), and he and I went through their catalog listings for Molyslip products, everything except Molyslip E has been discontinued. They did not list the assembly lubes AS40 and AS60. I need to find an online supplier of these things, this is ridiculus.Its not surprising, supplies of specialty stuff do not exist in Canada.
  #18 (permalink)
Old 07-11-2012, 09:17 PM
I have tbe cam installed all ready, without the Moly, guess that comes back out
  #19 (permalink)
Old 07-12-2012, 02:53 PM
F-BIRD'88's Avatar
Yada Yada Yada
Instead of making this into a 4day $100 project why not try using the telephone to find some moly paste. Why would you install the cam first , then start thinking about what cam lube to use?
The Home Hardware stocking number for the Moly Slip E is #8641-106.
Call the other store and quote this stock number. They either got it in stock or they don't. 5 minutes computer check.
Any of the local automotive supply stores will have a equal product-another brand to the Moly Disulphide Paste. "Isky REV lube"
This is not a proprietary product. Pretty much every lube company makes there version of it. And sells it in everything from small squeeze packs ( samle/single use to bulk 5 gallon pails of it. Every camshaft company has it.
Call them: Do not ask for moly grease.
If you want to know who else stocks the Moly Slip brand products,
email Moly Slip. They will probabily reply with a list.
Not that hard. They are on face book too.
Try these two convienient modern time saving inventions next time.
The telephone and the internet.
Camshaft lube requirements: Try reading the camshaft install directions.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
27TRoadsterguy (07-12-2012)
  #20 (permalink)
Old 07-12-2012, 02:55 PM
F-BIRD'88's Avatar
Yada Yada Yada
The Mcleod rd store has 3 cans of the Molyslip E oil suplement in stock.
Took me less than 45 seconds on the phone to find out.
  #21 (permalink)
Old 07-12-2012, 05:36 PM
A local machine shop owner, a member here, read this thread and called me. I have the needed materials.
Thanks to all who offered useful advice, it was much appreciated.
If you do not want to register, fill this field only and the name will be used as user name for your post.
Low oil pressure during cam break in truckboy61 Engine 12 12-10-2010 08:06 PM
Cam break in Oil question? truckboy61 Engine 12 10-10-2010 12:57 AM
cam break in oil change jafroyd Engine 2 04-13-2009 06:26 PM
Lifter rotation after cam break in Chevtec Engine 5 10-01-2007 10:38 AM
sucessful cam break in- what oil to use ? fast68 Engine 8 11-21-2005 10:28 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
