cam/lifter question - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-21-2011, 10:59 AM
cam/lifter question
been looking at cams and lifters and had a few questions.
1) cams come in mech. roller or flat and hydo. roller or flat.
how would it konw the difference between a mech or hydro roller.
or in the other case the difference between a hydro or mech. flat tappet the ends touching the cam are the same its the push rod end that's different aint it??
2) hydro seams to be better for most people and requires less maintenance but y is solid mech. more expensive you figure its got less technology in it and requires more maintenance that it would be cheaper.
3) whats the rpm limit of the hydro lifters weather it be roller or flat before you get all of the valve float problems and oiling issues.
Old 04-21-2011, 09:47 PM
32Essex's Avatar
If you're going to drag or spin it high rpm's go for the solid roller, if you going to drive it on the street, the hydraulic roller is the way to go. I run a solid roller in my 55 chev drag heap and set the valves every time i change the oil, it's just regular maintenance.
Old 04-26-2011, 10:38 AM
Then there's the guy who runs a solid roller driven on the street, spun to 8000 rpm's on occasion, and set the valves annually.
I think it all comes down to working knowledge of what you have, paying close attention to the sound of your car, how it runs, and using that working knowledge to catch problems before they become a catastrophe.
Old 04-26-2011, 03:10 PM
techinspector1's Avatar
Wiki Edits: 326
how would it konw the difference between a mech or hydro roller. Or in the other case the difference between a hydro or mech. flat tappet the ends touching the cam are the same its the push rod end that's different aint it??
I suppose an experienced eye could see the difference. An aftermarket cam will be stamped with the part number on the rear end of the cam, so you can reference it back to a catalog or call the mfg. The profile of the lobe is different between flat and roller. Experimentally speaking, you might get away with running a roller tappet on a flat tappet cam for a short while, but not the other way around. (heavy emphasis on "short while"). Roller cams are made from harder material than flat tappet grinds. That's the reason you have to make concessions with the distributor gear. A standard steel distributor gear is incompatible with the material in a roller cam.
Much more expensive materials must be used in a roller solid cam due to the abuse it will receive.
Just over 6000, but you can use a rev kit which consists of additional springs in the lifter valley to gain more rpm. Hydraulic tappets also come in an "anti-pump-up" design that will rev higher before floating. The limit on roller hydraulics is normally due to their weight. The roller wants to "loft off" the lobe profile and the spring can't control it. That's where a rev kit comes into play. But if you think about it, if you need more rpm's, you probably should have chosen a solid roller in the first place.
Old 04-27-2011, 02:29 AM
As techinspector already indicated, you can tell a flat tappet cam from a roller by the material. From what i experienced, flat cams are mostly cast iron and rollers made from steel (billets). FWIW, the first will have a black finish in between the lobes and on the shaft whereas a roller will have the same color throughout and you would also be able to see the machining marks on the shaft.
One more thing may be that solid will in certain cases make more power than a hydraulic because of the tight lash figures and absent hydraulic coupling in the lifter.
Just thought i'd add this, all the other info is detailed enough i guess
Lifter Tick / Lifter Face Wear Question rthjimmy Engine 6 04-19-2010 07:27 AM
Lifter Question? savman1 Engine 1 06-12-2008 09:16 AM
Cam and lifter question petiepye Engine 8 12-15-2007 08:45 PM
Lifter question outlaw17 Engine 2 01-04-2005 10:21 PM
Lifter question Sub_Urban_454 Engine 1 10-18-2003 05:10 PM
