cam and lifters - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-14-2010, 09:10 PM
cam and lifters
was looking at cams? what does duration and lift mean? i have a sbc 350 with edelbrock intake 600cfmcarb dynomax headers hei distributor....now which cam and lifter set????any maybe some suggestions for cheap heads???
Old 05-14-2010, 09:33 PM
Greg T's Avatar
www.krusinklassics.net
Pistons? Heads? Static C/R? Rear gears? Intended use?
Old 05-14-2010, 09:58 PM
everything else is stock sbc 350 from a 72 camaro now in a 66 caprice
Old 05-15-2010, 01:24 AM
vortec heads are pretty affordable and flow well.
Duration is how long the valves are held open. Lift is how much.
The more duration the higher the torque band is shifted and poor idle(lumpy). Less makes for more low end torque and smoother idle. It is give and take.
You need to decide what you are using it for and what rpm the engine will be operating. If you have highway gears and an over drive transmission you might cruise at 1800rpm. with 4.10's and no OD you might be at 3500 down the highway.
can any gurus explain "roller" v8mazda Engine 18 04-25-2010 03:12 PM
how much hp and torQ will my motor have xycho_wraith37 Engine 11 03-10-2010 12:14 AM
Hyd Roller Cam W/Solid Roller Lifters? RoyLeoGracie Engine 11 02-03-2009 10:15 AM
Damage to Cam Lobes and Lifters on 454. What caused it? leejoy Engine 50 11-30-2007 06:52 AM
Roller Lifters - standard cam ckucia Engine 27 01-27-2006 01:05 PM
