Cam Lobe Centers - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-23-2002, 02:09 PM
Stevestang1966's Avatar
Angry Cam Lobe Centers
Does anyone know exactly what lobe center is? If I have two camshafts both with the same duration and lift except one cam has a 110 lobe center and the other a 108 lobe center what would the noticeable difference be?
Old 06-23-2002, 02:15 PM
E.T. divided by $ spent= Speed
Post
I'm no cam expert but thge tighter the lobe sep the quicker the motor builds power and drops off.Tighter lobe seps tend to idle rougher too.The wider the lobe sep the more spread out the power is through the power band.
If i'm wrong someone correct me.
Old 06-23-2002, 02:53 PM
jeff of nc's Avatar
Post
lobe centers affect overlap. the 108 cam will have more overlap than the 110 cam if duration is the same
