Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam lobe seperation
Old 09-19-2008, 12:02 PM
454C10 454C10 is offline
The lobe centerline and the lobe peak lift is typically the same (as in your diagram). But not in asymmetric cams where there the opening ramp is different than the closing ramp which puts the peak lift off center.
