Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam lobe seperation
Old 09-21-2008, 11:49 AM
Stroke Stroke is offline
The cam is described as 'hot street', which advance ground in would be right for that description. Advancing for street use is the norm. I'd call Howard's to be sure, but you should simply install this one straight up as opposed to advancing. JMO
