Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam LSA question
  #29 (permalink)
Old 11-15-2012, 02:16 PM
tjet tjet is offline
Originally Posted by ap72 View Post
It may not be exactly period correct but a Torker intake looks very similar, can be picked up super cheap, and produces decent results- it's not as good as an RPM intake or something of that nature, but it does still have the look your after.
The current engine has a torker, but it's on an Olds 455 that I installed in high school. It has a bent rod, so I'm replacing it with a 350. I would like to keep the Olds, but I can't justify the 9-11 MPG. (My 350 vette will get around 17 mpg cruising at 65) + rebuilding a sbc is waaay cheaper. The Olds also had an overheating issue I just couldn't fix either.
I am going to use the current Olds TH400 though with a Summit adapter
ID:	69150   Click image for larger version
