Cam not compatible with overdrive? - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 08-06-2010, 04:49 PM
1983 Z28
Originally Posted by eric32
Well if it was my build with that setup I would go with the comp cam xe 256 h or at the very least the next one up at the most. I have the same rear end ratio as you do but I don't have overdrive like your 700r4 and I only have a 222/230 @ 50 cam and mine is barley acceptable going down the highway with a 2200 stall for my experience as to why I am putting in a smaller cam to give me better bottom end and midrange with out taking too much off the top.
I bet once I am done will have a nice night and day difference with street manners and performance and I will be much happier with how it will run. Bottom line it's up to you on what you want. That cam is still a little on the bigger side for street ability wise with good manners. My cam does not pick up till about 2500 rpm and it does not like it in town when the rpms are below 2000 most of the time. 1800 rpm is bare minimum and its best to be a little above the rpm band for bettor results.
My smaller cam will start to go at 1500 rpm and I am always above that going through town and mine will even work with a stock stall converter and with my 2200 rpm stall I should really wake up my bottom end some. Have fun I am sure you will get something worked out. At least your asking and taking advice to heart. Some just roll with it and don't care how it runs.
Eric
I know I'm stubborn, and to be honest I'm usually the one giving technical advice, but while I understand the different aspects of a camshaft's profile, I'm far from being an expert, which is why I'm here.
I'd rather be oversized than undersized a little with the cam, and from what I've seen the XE274 is designed exactly for my purpose. I haven't seen one person say they wished they went with a smaller cam after having the XE274.
I really don't care what the cam does below 1800 RPM. Like I said I don't need to be in OD cruising around town. As long as I can drive it around town in 3rd gear and cruise at 65-75 MPH with OD and the TCC locked, I'm a happy camper.
  #32 (permalink)
Old 08-06-2010, 04:53 PM
I would either change you cam choice or your gearing. The XE262 seems to do rather well for a Vortec combo. A roller would be better of course.
  #33 (permalink)
1983 Z28
Originally Posted by techinspector1
Do what you want to Junior, you're going to anyway.
No, that's not accurate.
For me to not use a combination just because someone tells me not to without telling me why, that would be pretty ignorant of me.
I need to hear why this combination won't work. So far it seems to be a well matched combo. Comp says it's a great fit, it's been proven to work well with overdrive transmissions, it's been used in conjunction with Vortec heads and 350's numerous times and makes an awesome power band.
Comp recommends a minimum of a 2200 stall converter. I will be using a 2600 stall converter. I'd rather it be a little tight than too loose for my daily driver.
What's wrong with this combination?
  #34 (permalink)
Old 08-06-2010, 04:55 PM
1983 Z28
By the way guys, gearing really isn't my biggest concern, I don't want that to limit my cam choice.
If I put the car together and the car is a dog or can't cruise in OD, I'll do a gear swap.
I have a Ford 8.8" from a 1998 Explorer with LSD, 3.73 gears, and disc brakes I've been contemplating installing. The offset pumpkin makes it difficult without modifying the axle tubes and shafts though.
  #35 (permalink)
Old 08-06-2010, 04:58 PM
Well I had a 700r4 in my truck before I took it and the vortec motor out and put a 350 turbo in its place but anyways the overdrive never kicked on till I was out on the highway. Most overdrive's from what I have seen don't come on till around 35-40 mph anyways so if you put it into normal drive should not be any issue cruising around town.
It's just you might have surging issues or you might not. Other factors there. Since you seem you are going to go that route hope things work out for you good. As far as going too small of a cam that would be putting a stock type cam or a rv type of cam
Even mine is a lot more then that type of cam. Well good luck bud hope it all works out and you don't have any issues. Please make sure you break your cam in with all precautions you can think of. Would hate to see you ruing your motor. I bet your camaro is fun to drive though.
Take care
Eric
  #36 (permalink)
Old 08-06-2010, 05:04 PM
Why not step down on the cam? What are you trying to accomplish by using a larger cam? On a street vehicle you'll be running slower from stop light to stop light and burning more fuel to do it. There are a LOT of Vortec builds with XE or Voodoo 262 or 268 cams- I would take a look at those.
I don't like running aggressive hydraulics like those series (What's the plural of series?) but if you want to run them then I would go with a 262 or 268. If you want a rougher idle have it ground on a 106 LSA; just be sure to have good headers and exhaust if you do that.
  #37 (permalink)
Old 08-07-2010, 06:47 AM
Overdriv's Avatar
I just drove my pro street S10 150 miles round trip yesterday, so I tried running at different speeds to see what would happen. I have a XE274 cam, 406 SBC, 700R4, 4.56 gear. Keep in mind the XE274 will seem a bit bigger to a 350 than the 406.
At 1500 RPM in OD TCC locked, it would buck and surge on the cam. 1800 was the slowest I could go and be right on the edge of the cam. 2000 RPM it was smooth at just under 55. I usually cruise about 2100 RPM just shy of 60 MPH in OD locked. It will do that all day and get 15-16.5 MPG with or without the AC.
When I slow down to go through a town, I shift to 3rd. This also unlocks the TCC. Around town, I never run in OD, always in 3rd. My truck will shift into OD/locked at 35MPH, and it ain't pretty, buck and jump time, you get to listen to the slack in your drive line and suspension.
I can't imagine running it with a 3.42 gear. 4.11 would be border line.
Get and use one of the many speed/RPM calculators and do your own what ifs. Be realistic with your estimations.
I'm trying to give you some real experience with a combination very similar to what you are proposing. I still think you can keep the cam selection you want, enjoy the big cam sound, but in my opinion, you need to re-gear for it.
  #38 (permalink)
Old 08-07-2010, 09:57 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Originally Posted by Jr. Mechanic
Well right now I'm leaning towards the XE274H. Seems to be the most aggressive cam I can run. Comp calls for a 2200+ stall converter, and says the operating range starts at 1800 RPM.
Thoughts?
Just pipping in on operating range listings that the cam companies are using here, how accurate are they really? It could be that too many folks get caught when they look at the these numbers cause they are not considering the rest of there combination. Consider my lunati 301A8LUN http://webcache.googleusercontent.co...&ct=clnk&gl=us
Let me assure you that with my vortec headed 383, 700R4, 3.73 C10 it makes for a good combination for me, its listed operating range is 1000-5800, however as an example even at 1700 rpm in overdrive its is not happy and the engine is a lug, drop in to 3rd and different story or cruise up to 2500 in OD and hang on. Just pointing this out (as others have) because you have the 700R4 and plan on some highway cruising, don't put too much into the posted operating range when making a choice. IMHO you need to stick with a smaller cam than the 274 (not too mention the probable valve train racket), but again its the cake and eat it deal, better at WOT or a good driver. As I mentioned I had bought the blue racer 214/224 from skip and was going to use it on my build, some days I wish I had but since I only run through maybe a tank of gas on the weekends during the summer, bigger is OK to a point. And if you want to talk about cold start problems?, better get a block heater, yes most our rides up here have a plug in sticking out of the grill
  #39 (permalink)
Old 08-07-2010, 10:15 AM
1983 Z28
Okay, well I shifted my attention to the XE268H. I see no reason this wouldn't be a good choice.
Would it be beneficial to run 1.6 ratio rockers with this cam?
  #40 (permalink)
Old 08-07-2010, 05:51 PM
ericnova72's Avatar
More for Less Racer
On the intake side yes, won't make a difference on the exhaust side.
  #41 (permalink)
Old 08-07-2010, 08:58 PM
1983 Z28
I already have a set of ProForm 1.5/1.6 ratio RR's, but I'm getting rid of them due to many I've seen break. Am I best off getting another set of 1.5/1.6 ratio RR's or just getting a set of 1.5's or 1.6's?
  #42 (permalink)
Old 08-07-2010, 09:09 PM
ericnova72's Avatar
More for Less Racer
I'd use a split set if it was me.
  #43 (permalink)
Old 08-07-2010, 09:19 PM
cool rockin daddy's Avatar
Boy! Quite the thread. Comp XE 268 with Vortecs, 1.6 rockers, and a 750 cfm carb made 418 hp. The people that built the engine said the XE 262 would be an even better cam. Lose a little on top end and gain even more torque. Go to comp's site and look at the power curves of the XE cams. They all make basically the same HP and TQ, just the curves where they make the power are moved up the rpm band. I run a 262 and am very happy with the power and the idle.
What was/is your other user name, Jr. Mechanic? You're posting style of not listening to any suggestions no matter how good they are and claiming that people ask you for tech help is very reminiscent of a few other posters that were laughed out of the forum.
  #44 (permalink)
Old 08-07-2010, 09:29 PM
hemi joe's Avatar
loves ex cop cars
cool rockin daddy,i love your style............joe
  #45 (permalink)
Old 08-07-2010, 09:56 PM
I try, joe.
Cam button length/clearance..? mrdreex Engine 1 04-12-2008 11:17 PM
Cam Selection and Dynamic CR Arcuden Engine 8 03-23-2008 12:03 PM
I need cam help 355s10 Engine 5 03-16-2008 06:34 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 02:11 PM
another cam ouestion...ie...cam timing VETTE GUY Engine 0 06-28-2003 12:29 PM
