cam oil-hole placement sbc - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2012, 10:29 PM
snydski's Avatar
snydski
Last journal entry: 72 ' 3970010
can anyone tell me if it makes more sense to place cam oil hole above or to the left of the 12 oclock position,( facing front to back uprite engine oreintion . ) to let the oil out of the supply at the lowest point of resistance or is the argument that the pressure forces the bearing to load oil on the race and away from the hole . And the reason I say to the left of 12 oclock is to even out flow to the lower end mains .. Any thoughts ?
stripped hole by steam hole one 400sbc projectman69 Engine 11 11-06-2011 09:30 AM
2 hole exhaust flange connecting to a 3 hole JLBpontiac350 Engine 0 04-26-2011 02:31 AM
Cracked steam hole going to bolt hole projectman69 Engine 4 11-10-2010 07:54 AM
PVC hole placement frank88chevy Engine 0 10-11-2007 08:56 AM
67 Camaro shifter hole placement Doug Graham General Rodding Tech 1 04-16-2007 03:24 AM
