Is this cam ok with 416 heads? - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-30-2012, 07:25 AM
Brandon H.'s Avatar
So I got a 305 with 416 heads for cheap (yes I know a 305, it's a mud truck so it's not getting a lot if $$ in it). With it I got a new cam, lifters, stock rockers, timing chain and flex plate and moroso valve covers
I have no idea if the heads have any work done but I don't believe so. This is the came he gave me, but I'm thinking it may be too much lift
Crane Cams 10008 Crane Cams Energizer Cam & Lifter Kits
Can I run this cam? I'll run a 2500 converter with 4.10's.
Also I may have more info on it later, not sure if it has flat tops. About to do a leakdown test after church.
Old 12-30-2012, 07:35 AM
Banned
For stock 416's that's a little big. I'm sure F'bird will get on here and do his sermon on the porting the 416's mount, and if you have the time to do it it may not be a bad idea since it's basically free (just time consuming).
BUT for stock heads you may wan to step down to the 274h06 or equivalent cam, you can buy that cam for about $70 too. For either cam getting a set of headers and free flowing exhaust is a must.
Old 12-30-2012, 08:12 AM
What size tires will you be running .this is the cam I use in my 355 mud truck it may be a little to big for a 305 .. Crane Cams 10005 Crane Cams Energizer Cam & Lifter Kits
Old 12-30-2012, 08:21 AM
Old 12-30-2012, 08:28 AM
Brandon H.'s Avatar
I'm running 33's, it's a 79 K5 with 4" lift
Old 12-30-2012, 03:33 PM
techinspector1's Avatar
Wiki Edits: 326
Brandon, let's do some math.
A. 2500 engine rpm's with a 4.10 gear and 33" tire will produce 60 mph vehicle speed.
B. 2500 engine rpm's with a 3.43 gear and 28" tire will produce 60 mph vehicle speed.
From this, hopefully you can see that you will need more gear, particularly with a small displacement motor like the 305. I don't think anyone would recommend a Crane 10008 cam to you if you had a 3.43 gear and 28 inch tire. They would tell you to get more gear. Actually, with what you have now, a stock cam or just over stock would work best in my opinion.
The Following User Says Thank You to techinspector1 For This Useful Post:
Brandon H. (12-31-2012)
Old 12-30-2012, 09:55 PM
Brandon H.'s Avatar
Thanks guys for the feedback, I guess I'm going a different route. I had a feeling that's too much cam.
How about this little guy?
Summit Racing® Camshafts SUM-1102 - SummitRacing.com
I was after something with a little loap, even if it hurt low end torque. Like the price tag on that cam. Unless someone could recommend something else. I'm getting a new torque converter anyways too so maybe something with a lower stall.
Old 12-30-2012, 10:18 PM
Wiki Edits: 326
There's your problem.
Old 12-30-2012, 10:35 PM
Brandon H.'s Avatar
I'm young and stubborn, everyone has been there
After all chances are it just gonna swallow water one day and lock up. It's just a mud truck as long as it sounds good I'm happy
But really, I thought that summit cam 1102 would be a nice mild cam? Should be able to run stock springs? Stock dished pistons, 416 heads, leakdown test looked great, but still have 3 cylinders left to check. Nothing impressive by any means, but the 350 in the truck now burns oil bad.
Old 12-31-2012, 12:21 AM
vinniekq2's Avatar
whats the gear ratio in the transfer case? 4.1 X ?
Old 12-31-2012, 04:57 AM
Np 208 2.61.1 .....:....np 205 1.96.1.......save your money and swap in vortex 350 roller motor ...what's the plain for the truck ...what kind of tires. I think a stall would be a mistake.... torque is king in off road
Old 12-31-2012, 05:05 AM
Old 12-31-2012, 07:03 AM
Banned
is this a competitive mudding truck, or a toy mudding truck? If its just a toy then don't worry about every last hp, I've gone mudding with little 4 bangers, and a lot of other people have to. Actually, the most important part of building for mud is DURABILITY. Don't max out your compression ratio and run extra cooling for when it packs full of mud.
hitting old forrestry roads is a LOT different than competitive mud bogs, and I'm not sure which you're referring to.
Old 12-31-2012, 08:13 AM
BigEd36's Avatar
Brandon, the Summit K1102 you mentioned would be a WAYYYYY better choice than the Crane 10008. The K1102 grind is considered a "torque cam" or "rv cam".
Old 12-31-2012, 08:17 AM
BigEd36's Avatar
Even the Summit K1101 is a little more cam than the factory cams in most 305's, it has just slightly more lift than the factory 300 HP 350 cam.
cam specs on a roller cam for a 416 stroker terry2012 Engine 1 01-21-2012 02:13 PM
416 Heads on a 350 Mertz Engine 3 12-27-2011 03:30 PM
416 heads ap72 Engine 0 04-17-2009 09:56 AM
416 sbc heads brandon624 Engine 4 10-17-2007 02:05 PM
what cars came with a 416 305 heads 78novafan Engine 2 02-05-2006 11:31 PM
