cam and quadjet question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-10-2007, 11:38 PM
i have a 350 40 over 882 heads ported and polished with screw in studs and aftermarket springs vodoo 262 cam edlebrock performer intake 1 1/2 headers. the question i have and am trying to break in cam and have 3 or 4 times had to shut off because first glowing red headers, second plug wire got burnt up, move the wire away so not touching and it still burnt up, got a wire protector so dont burn anymore and it back fires. the carb is a 750 holley that i traded some guy for 600 i had. i have it at 8 degrees advance. so my question is one have i damaged the cam by turning off and on the truck before 20 mins break in and two i think the carb needs to be rebulit and want to put on the 4 bbl quadjet i had on 305 on and breakin cam with that. but is it goin to make my truck run to lean with quadjet on there. if anyone has any suggestions i am all ears. i just want to get the thing running.
Old 06-11-2007, 12:46 AM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
I think the cam should be fine. It is supposed to get fast idle for 20 minutes total. Of course that is best if its getting constant splash from the crank (which is the reason for the fast idle) but I think it should be fine as long as its FIRST twenty minutes is operated at fast idle.
If you read your header's paperwork it says specifically not to use them for break in. Break in temps are very high, especially in the exhuast. Jet Hot specifically voids warranties if you use headers for cam break in. Red-hot headers are to be expected.
I keep a set of manifolds around just for that purpose. Let them take the abuse, not the new headers.
Old 06-11-2007, 12:51 AM
DoubleVision's Avatar
So the next best thing, since you already have headers on it is to bring a fan over and let it blow on the engine area to carry the heat away.
Old 06-11-2007, 01:04 AM
curtis73's Avatar
Wiki Edits: 16
Not really. The biggest problem is sustained fast idle with choke. You're shoving massively rich mixtures into the exhaust and it keeps burning making problems.
You might be able to stave it off by kicking the choke off and then holding the throttle open. The main thing is that cam lobes ONLY get lube above about 2000 rpms from crank splash. If you start it, then kick off the choke and keep it somewhere above 2000 rpms (within reason... don't go nuts) it should be fine.
A fan wouldn't hurt, but the main problem is extreme EGT.
Old 06-11-2007, 10:14 AM
Jmark's Avatar
Sounds like more timing would help too.
Old 06-11-2007, 07:57 PM
so quadjet might be ok just to breakin the cam for 20 to 30 mins??
Old 06-12-2007, 08:36 AM
The timing is too retarded!!! Advance the timing 15 degrees and the headers will stop glowing.
Old 06-12-2007, 09:24 AM
curtis73's Avatar
Wiki Edits: 16
Depending on the engine (especially one with a little more cam in it) you could advance the timing to hell and back and the headers would still glow cherry red. You're dumping tons of extra fuel (like maybe as much as 5:1 AFR) into it during break in, so no amount of advanced timing will burn all that liquid fuel.
Even if you drop off the choke and hold the throttle open manually, you're still operating at a very low throttle opening cruise.. which puts it on the lean limit which (again with a hefty cam) will raise EGTs. You don't get the fuel burning in the exhaust like when the choke is on, but the exhaust gasses are hotter. Heck, even my cast iron manifolds glow red in the dark after a cruise in my LT1 with 103k on it. Its just a fact of life. Exhaust is hot, and cam break-in is asking a lot from your exhaust.
That is why header manufacturers void warranties if you use them for break in.
Old 06-12-2007, 05:59 PM
In most cases when is a car sitting at high idle for any period of time? at cam break in, you really won`t do it at any other time. The fuel mix can be dead correct and the timing on the money and they`ll still glow. with the car not in motion there is no airflow to carry the heat away. That`s why the fan was recommended. I`ve seen many a dyno run and they bring a fan in to create air flow to prevent the glowing headers. If in doubt the of the mixture being off, you can use the accelerator pump as a reference since you can work it without moving the throttle. give the acc. pump 4 or 5 good shots of fuel, if the glow starts to go away it`s too lean, if the glow intensifies, it`s too rich.
cam choice derek32303 Engine 8 03-04-2007 07:32 PM
