CAM + Quench Questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-23-2007, 06:50 AM
383 w/Dart Iron Eagle Heads 64cc. SP pistons -12cc. .040 head gasket presently. I'm installing a solid roller .567 / 242 dur @.50. Cam is asking for more compression as mine is 9.67 now. Thinking of a .015 steel shim gasket or flat milling heads about .025 puts me around 10.27.
Cam is 110LSA, ICL is 106 -duh! if I install straight up does this mean I will be at 106 CL or do I advance to achieve 106. 106 is where I want to install.
Any thoughts bout compression is appreciated. I don't know about QUENCH with these pistons, I assumed dished pistons were for controlling detonation.
I will measure quench later today when I get heads off.
THANKS!
Old 05-23-2007, 08:11 AM
You install straight up, dot to dot on the gears. The advance is ground into the cam.
'74 Corvette 454 dyno results- Comp Cam XE 274H questions Bob Turner Engine 12 05-19-2005 10:59 AM
More cam questions bamacj Engine 5 12-30-2003 06:34 PM
HEADS, CAM, and QUENCH DTL504 Engine 4 11-09-2003 12:22 PM
Stock crate 350 (Cam Questions) Savage64chevy Engine 3 01-21-2003 12:34 PM
cam and stall converter questions dk01_99 Engine 10 01-03-2003 10:57 PM
