Cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-21-2008, 08:30 PM
J77 J77 is offline
Cam question
Hello everyone, I recently installed a new Crane Energizer Cam duration 226/226, lift .533/.533 with new lifters in a 73 Chevy 454 that I'm trying to do my first rebuild to. I talked to a Summit Racing tech and he said that cam would be no problem for this motor. My question is that some of the lifters sit dead on top of the lobes but some are not running exactly on the lobe. Is this normal? Something just seems off to me about it. The timing gear and cam gear are perfectly aligned. This is my first rebuild and am having a lot of issues with it. I was trying to insert an image of it, but can't. Please any help would be greatly appreciated on what the problem could be if any.. Thanks again..
Old 07-22-2008, 04:58 AM
Turn the engine over with the intake manifold off and watch the relationship between the cam lobes and lifters change. I think you'll see everything's fine. I would do this before you install the pushrods.
Old 07-22-2008, 03:04 PM
J77 J77 is offline
O.k. will give it a go.. Thank you so much..
cam and quadjet question derek32303 Engine 8 06-12-2007 04:59 PM
Chevy cam question buzz1961 Engine 1 02-21-2007 04:02 PM
Another Cam selection question NWayne Engine 17 02-01-2007 12:28 AM
cam question dboyett38606 Engine 8 01-23-2007 02:13 PM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
