Cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-19-2008, 08:58 PM
Cam question
hey guys I have a custom grind cam in my bbc that when I tore down the motor I noticed it has little bit of chewing on the dist. gear I've since then bought a bronze gear my ? is is the cam still useable it looks like it ate in about maybe half the thickness of a fingernail
I'd like to use this cam since one its a custom grind two it made my motor into an animal and three I got it real cheap from a friend that builds off shore race boat motors
Old 08-19-2008, 10:56 PM
it was fine when I got it. running the motor for about 20 mins to set the lash and break in the lifters is what ate it up a little and its not a cheap hyd cam its a Jones custom grind solid roller
Old 08-19-2008, 11:23 PM
thanks I had heard that at one time but wasnt sure if it was true ( the repairable dist. gear ) I would think with the cost of a replacement of this cam it should have the pressed on gear I have to call Jones in the morning I choked when I talked to them about a replacement cuz it was in the ballpark of $850 for the same grind cam
cam and quadjet question derek32303 Engine 8 06-12-2007 04:59 PM
Chevy cam question buzz1961 Engine 1 02-21-2007 04:02 PM
Another Cam selection question NWayne Engine 17 02-01-2007 12:28 AM
cam question dboyett38606 Engine 8 01-23-2007 02:13 PM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
