Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Question
Thread: Cam Question
Old 03-02-2012, 12:19 PM
techinspector1's Avatar
techinspector1 techinspector1 is offline
Wiki Edits: 326
If your static compression ratio is truly 9.00:1, then the dynamic compression ratio with this cam will be 8.09:1. (intake valve closes at 32 degrees ABDC).When I read your first post, I thought the motor would be a typical low compression boat anchor (around 8:1).
That cam will work fine on pump gas and yield decent power. If you want more low end, use a cam that's a little bit smaller, to raise the DCR some. Maybe a cam with 5-7 degrees less at 0.050".
Are you paying attention to the squish?
