Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Question
Thread: Cam Question
Old 02-09-2013, 01:01 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Originally Posted by pilona42 View Post
I did set them dot to dot. I even double checked it yesterday. So a hissing sound coming up through the intake is normal?
You are likely hearing it leak past the piston rings. If the cranking compression is 150 its good.
On a stock OEM cam the intake is not fully closed until 40deg ABDC +/- The piston is approx 1/3 past BDC
The bigger the cam the later the intake closes (generally)
Did you verify accurate timing tab TDC location, using a piston stop to find true TDC?
often a issue with non stock aftermarket parts. inaccurate timing setting is the result.
what cam?
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
pilona42 (02-09-2013)
