Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Question
Thread: Cam Question
  #19 (permalink)
Old 02-09-2013, 03:21 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
If the dots are not infact lined up the cam will move approx 20deg for each tooth it is out.
a non stock cam will need a non stock timing curve. usually a lot more initial idle timing.
if it was the 350-290HP GM crate motor it has a high perf cam and will like a moderate increase in idle timing
18 to 24deg at idle is typical.
measure the cam lobe lift. a wiped cam lobe is a possibility watch the rocker motion as the engine turns.
