cam question - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-17-2009, 12:27 AM
old76c10's Avatar
all jacked up on mountain dew
cam question
ok i just picked up a 40 over 350 its in pieces but i got an edelbrock roller cam and retro fit roller lifters out of the deal all look to be in good shape...can i reuse the lifters with a different brand cam that i like better? it would sure save a bundle if i can
Old 09-17-2009, 12:40 AM
ericnova72's Avatar
More for Less Racer
If they are unhurt, yes you can.
Old 09-17-2009, 12:48 AM
old76c10's Avatar
thank you very much they seem fine and the engine was running good before it was tore down to do a head swap then they decided they wanted to go bigger but just in case is there anything i should do to them? they are hyd roller lifters
Old 09-17-2009, 01:50 AM
if rollers are in good shape than yes you can reuse them. regular flat tappet hydo lifters never get reused unless on the same cam on the same lobe and in good shape.
cam and quadjet question derek32303 Engine 8 06-12-2007 04:59 PM
Chevy cam question buzz1961 Engine 1 02-21-2007 04:02 PM
Another Cam selection question NWayne Engine 18 02-01-2007 12:28 AM
cam question dboyett38606 Engine 8 01-23-2007 02:13 PM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
