Cam Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-01-2012, 04:21 PM
400smb_s10's Avatar
Back Yard Junky :)
Location: Around the Corner from the middle of nowhere... Arden Ontario
Cam Question
I just purchased a Cam this morning at the auto parts store for my 400 sbc and they suggested this one for me
288 dur 443 lift and 110 LSA
Will this work good with my stock 400?
any input will be appreciated
Thanks
Ed
Old 03-01-2012, 04:51 PM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
I doubt it. Depends on the static compression ratio of the motor.
Old 03-01-2012, 05:29 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Thanks
Ed
Need to know the gear ratio/stall speed, weight, CR, what heads you have, intake and exhaust system, what you expect it to do/how it'll be used, and anything else pertaining to it that's known.
What cam is this? Specs? I'd expect the cam to have around 230 degrees @ 0.050", but that's just a guess. I'd also guess that the dynamic CR is gonna be low. At least there shouldn't be a problem w/detonation, but power could suffer especially the bottom end. The displacement makes up for this a little, but it still may well be quite a mismatch, depending on what you have.
Old 03-01-2012, 07:06 PM
BigEd36's Avatar
What is the duration @ .050"? It seems like a lot of advertised duration for only being .443 lift.
Old 03-01-2012, 07:29 PM
400smb_s10's Avatar
Back Yard Junky :)
Stall speed is stock. Rear gears 3.73 tranny is a 700r4. Comp ratio is 9.0:1. Its for my street truck. I just want it to be able to letter rip once and a while.
Heads are 3973493 1.94 1.5
4bbl 600 cfm Qjet carb
Old 03-01-2012, 07:40 PM
400smb_s10's Avatar
Back Yard Junky :)
Hydraulic Flat Tappet, Advertised Duration 266/266, Lift .440/.440
this is the one that i was told to get but all they had was the 288/288 duration and .443/.443 lift so that is the one that I was told would work good
Old 03-02-2012, 06:58 AM
All cam grinders have a different method of measuring "advertised" duration. For a more "straight-forward" comparison, the @.050 numbers are more useful. Also, each cam grinder has a different "approach" to making power and the corresponding lobe designs or "shapes'. Not all cams are "equal", even if their "@.050" and lift/LSA numbers are the "same".
That being said, what is the brand name and part number? That's the best way to determine if this cam will suit your needs.
Jim
Old 03-02-2012, 09:49 AM
400smb_s10's Avatar
Back Yard Junky :)
Duration @ .050" 214 int 214 Exh
SAE duration 287 287
Lobe spread 105 115
lash Hydraulic
Valve Lift ".444 ".444
Cam Lift ".296 ".296
The maker of the cam is MAHLE GROUP and the part number is 229-1987
Hope this give you all the info needed
Thanks for all the input so far
Old 03-02-2012, 11:47 AM
Good. The manufacturer is Camshaft Machine in Illinois (they may have relocated). it is a "generi-grind" sold by several vendors, including Melling, Elgin, Edelbrock, Mahle, Wolverine, etc. (all marketers, none are cam grinders). Currently, CMC "soes" most of the flat-tappet hydraulic V8 grinds for MOSTcam sellers including Comp and Crower. Of course, Comp, Crower, Lunati all supply their "own" masters and the grinds are propietery.
This is a mild performance grind. It should offer a pretty smooth idle and will be fine with a "stock" converter. For a little better top-end performance, use "Z/28" (or similar) valve springs. NO "rotators" on the exhaust valves!!! Stick with 1.5 rockers. If you do upgrade the springs, a 1.6 rocker on the exhaust "side" will pick you up some performance. Most modern grinds are "dual pattern". This one is a "single" pattern (both lobes "look" alike).
Comp's old 260H grind is CLOSE. It's 212 @ .050. It has an LSA of 110, though. The stated power range for the Comp cam is "1,200 - 5,200". I suspect this cam would bring the power "in" a tad sooner (the LSA) and not be quite so "peaky" as the Comp, "spreading" the power to the same upper limit. Important to note, differences in performance between the two would be minimal with a grind this "small".
For a 400, this would be a "torque" grind, probably running out of "breath" closer to 4,800 than 5,200. What exactly do you want it (the engine) to "do"?
Jim
Old 03-02-2012, 12:19 PM
Senior Curmudgeon
Wiki Edits: 326
If your static compression ratio is truly 9.00:1, then the dynamic compression ratio with this cam will be 8.09:1. (intake valve closes at 32 degrees ABDC).When I read your first post, I thought the motor would be a typical low compression boat anchor (around 8:1).
That cam will work fine on pump gas and yield decent power. If you want more low end, use a cam that's a little bit smaller, to raise the DCR some. Maybe a cam with 5-7 degrees less at 0.050".
Are you paying attention to the squish?
Old 03-02-2012, 01:51 PM
F-BIRD'88's Avatar
Yada Yada Yada
That cam will work very well for your purpose. It will make more power than stock , expecially with headers and improved exhaust.
re 1.6 ratio rockers on a SBC.
The 1.6 rockers go on the intake side if you want a bit more power from high ratio rockers. ( you gain a small amount of top end power with the increased intake lift, especially if the cam is mild, especially if the heads have been ported. The exhaust side on a SBC head responds more to a duration change.
Often adding extra exhaust valve lift w a rocker ratio swap , shows no gain or reduces power.
keep the 1.5s on the ex side
Old 03-02-2012, 02:04 PM
400smb_s10's Avatar
Back Yard Junky :)
Ok so I should swap out all the springs to 1.6? or just the intake and intake rockers?
I also ment to mention that the exhaust is 1 3/4" shorty headers into 3' exhaust no cats and glass packs
I want this engine to work well for me. maybe take it to the track on a saturday night but I mostly want it to have a little more ummph then stock. I would like it to be a nice cruizer motor but when i want to get up and scram I will be able to do so.
Old 03-02-2012, 02:34 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Lobe spread 105 115
lash Hydraulic
Considering this was a cam hat was chosen because the "right" cam wasn't available (not usually the way you'd like to go about picking a cam, as I'm sure you would agree), it isn't a bad choice. The lobes are gentle (lot of advertised duration to the amount of lift) so it will be easy on the valve train components, but it will give away some lift "under the curve" that is offered by the fast lobe cams like the Comp XE-series and the Lunati Voodoo series cams. But given the sad state of affairs regarding the current "over the counter" motor oil additive packages, having a less aggressive lobe isn't necessarily a bad thing.
TI has run the DCR for you and deemed it to be OK, so all that is left is to get it installed and broken in. THIS Wiki page has a few articles that could be of some use to you, like:
• Adjust valves
• Camshaft install tips and tricks
• Valve train points to check
Good luck.
Old 03-02-2012, 04:12 PM
Senior Curmudgeon
Wiki Edits: 326
On most of the Dynosims I have run, the motor will pick up only single digit gains (less than 10 hp) with higher ratio rockers. Plus, there is more strain on the whole valvetrain with them. If you were racing in some competitive venue and needed to gain a headlight rim on your competitors, and had exhausted every other avenue of gaining a few hp, I might tend to recommend higher ratio rockers. But if this is in any way a street driver, leave the rocker ratio alone. That's my best advice.
Shorty headers will work better than stock cast iron manifolds, but will be short on power when compared to long-tube, tuned headers.
With 9.00:1 SCR, this motor will not be a world beater. It will make good power with a stock converter, but if you want to "get up and scram", you're building the wrong motor.
Old 03-02-2012, 05:21 PM
F-BIRD'88's Avatar
Yada Yada Yada
From your confused response re; 1.6 rockers, just use the 1.5 rockers. They are just fine.
If you want it to really scream get some L-31 vortec heads and a vortec style 4 bbl intake manifold for your 400.
Big big difference in "truck power and torque" from stock 400 SBC heads.
the stock 400 heads are lame. Now the cam can work.
Don't forget to hang on
Question about vehical weight and engine question Thuggishruggish3000 Engine 12 03-24-2011 05:22 AM
sbc timing question and carb question.....i am ready to absorb your knowledge c_cham Engine 16 02-12-2011 11:26 AM
steering question and brake booster question Hwyhogg Suspension - Brakes - Steering 0 11-21-2010 05:02 PM
Timing question and cylinder head question.. Blackhauk90 Engine 3 05-22-2007 01:10 PM
not a rod question but an engine swap question for a daily driver.. DeathByGreaser Hotrodders' Lounge 2 01-22-2004 10:59 PM
