Cam Question - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-09-2013, 01:43 PM
Richiehd's Avatar
JS-70
Sounds like maybe the cam is wpied a lobe or maybe you have a timing chain set withe the 3 different settings and you have the marks wrong.
The Following User Says Thank You to Richiehd For This Useful Post:
pilona42 (02-09-2013)
  #17 (permalink)
Old 02-09-2013, 01:45 PM
Originally Posted by F-BIRD'88 View Post
what crate motor? they do not all have the same cam in them?
what else did you change.. everything...
Just put a set of fresh 2.02's on and a Q-jet intake. New cap, rotor, wires and plugs. The lower end came from a buddy that had a problem with it so he just bought a new long block. I tore it down and found 3 burnt intake valves. He told me it only had 12,000 miles on it and compression was good. As for the cam specs. I dont know. Is it possible the lift/durration is incompatable with these 2.02 heads?
  #18 (permalink)
Old 02-09-2013, 01:48 PM
Only 1 keyway in my crank gear! Its my understanding that with that setup it is impossible to be so far off that it wont run as long as the dots are lined up. Would you agree?
  #19 (permalink)
Old 02-09-2013, 03:21 PM
F-BIRD'88's Avatar
Yada Yada Yada
If the dots are not infact lined up the cam will move approx 20deg for each tooth it is out.
a non stock cam will need a non stock timing curve. usually a lot more initial idle timing.
if it was the 350-290HP GM crate motor it has a high perf cam and will like a moderate increase in idle timing
18 to 24deg at idle is typical.
measure the cam lobe lift. a wiped cam lobe is a possibility watch the rocker motion as the engine turns.
  #20 (permalink)
Old 02-10-2013, 12:42 AM
Think I found the problem. Had the intake off and checked my lifters. Sure enough they were all stuck up. This motor sat in my shop for a couple years and that must have done them in. Gonna throw a new set on in the morning and see what happens.
If you do not want to register, fill this field only and the name will be used as user name for your post.
cam question dsdrag Hotrodding Basics 1 04-19-2012 10:14 PM
another cam help question cbr954rrider Engine 5 10-27-2010 09:29 PM
general question - single cam vs twin cam KoTT Engine 4 09-23-2009 02:46 PM
cam question old76c10 Engine 3 09-17-2009 01:50 AM
Cam question babygene41042 Engine 2 09-10-2008 04:42 PM
Copyright ©2000 - 2014, vBulletin Solutions, Inc.
