Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - cam question
Thread: cam question
Old 02-19-2007, 08:41 AM
baddbob baddbob is offline
What pistons can make a huge difference on compression ratio, example- with 64cc heads some flattops will be only 9.3-1 while others will be well over 10-1. Knowing the static compression ratio will help determine how small you can go on the cam with pump gas.
