Cam Question - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2006, 06:23 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Cam Question
All engine factors the same, identical lifts, and timed the same at 104* advanced,
what is the difference between these 2 cams?
270 x 270 on a 108* LSA
270 x 280 on a 110.5* LSA
Old 07-16-2006, 06:49 PM
nitro_baller4692's Avatar
floppers forever
this 108*and 110.5* is lobe center separation.the difference is 2.5* .
these numbers are used in cam phasing.why do you ask?
Old 07-17-2006, 10:37 AM
xntrik's Avatar
up to page one
Old 07-17-2006, 06:21 PM
floppers forever
i think you mean 4*advanced.yes or no?
Old 07-17-2006, 08:05 PM
powerrodsmike's Avatar
Wiki Edits: 161
I know this is a test.
I'm going to try it and show that:
A) I know a little bit
B) I know nothing. (There is that possibility, but I'm doing the test anyway)
I am going to assume that the numbers you gave are duration @ .004" or .006"
I would say that the 270 X 280 would run better on the top because of the longer exhaust duration and even though the LSA is wider the longer exhaust duration gives 2 1/2 degrees more overlap and makes for better scavenging.
I'd say it would sound better than the first cam at the pipes too because of the 7 1/2 degrees more advanced exhaust timing.
I would say that the powerband would be a little wider with the second cam because of the wider LSA.
It looks like a good cam for a smaller motor in a truck.
Unless those numbers you give are duration @ .050"
If that is the case then I doubt you would be pulling a trailer with that motor. Tractor pull weight sled maybe.
Did I get any of that right?
Mikey
BE different....ACT normal.
Old 07-19-2006, 03:31 PM
xntrik's Avatar
OK advertised duration...
This is not intended to prove anybody stupid, etc. Just a simple lesson in camshafts.
Think how cams are measured and timed.
Remember the exhaust stroke comes before the intake stroke.
You are on the right track, think it through carefully.
What is the difference between the two cams specified in # 1 ?
It is simple, easy, and confusing.
Old 07-23-2006, 10:00 AM
xntrik's Avatar
Nitroballer, you are correct. My addition of the superfluous word "advanced" was incorrect. The intake lobe is centered AFTER Top Dead Center.
The specifed cams and their timing are absolutely identical in every aspect except that the exhaust valve opens 10* sooner. It is termed a nitrous cam.
There are 4 events of importance.
1) intake opening
2) intake closing
3) exhaust opening
4) exhaust closing
Remember that the camshaft turns 1/2 as fast as the crankshaft.
Lobe duration is crankshaft degrees, and LCA/LSA are in camshaft degrees.
"To make this cam function better when the nitrous is on, the exhaust valve might want to be opened 10* earlier. That earlier opening is the only valve event to change in relation to the crank angles involved. But because of the way we quote advance based on LCA, it makes the cam spec look much different.
....we find the cam, with a 10* earlier exhaust opening, is now a 270 x 280 with a 110.5 LCA. If the intake centerline is held in the same place as for the non-nitrous cam at 104*, we find that it is now 6.5* of advance.
....a cam on a wider LCA and plugged in with more advance."
David Vizard, PHR magazine, Aug 2006, p 80, Timing is Everything/ Advance or Retard- What's Needed?
Hope you enjoyed the brain teaser.
Cam Question TonyMac Engine 7 09-23-2005 12:31 PM
goodwrench crate motor/ cam question 72chevy240z Engine 25 04-07-2004 07:14 AM
1987 dodge 318 cam question 74huggerorange Engine 5 12-21-2003 09:54 AM
cam question beetle9 Engine 1 12-06-2002 10:23 AM
Cam question Jare Engine 3 11-27-2002 03:18 AM
