Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - CAM Questions
Thread: CAM Questions
Old 07-02-2012, 09:02 PM
Richiehd's Avatar
Richiehd Richiehd is offline
JS-70
Cam lift is lobe lift. Valve lift would be with rockers installed. You should have got a card with that cam with both cam and valve lift on it. Springs should be ok. Dont forget your 1.3 breakin rockers or pull the inner springs for breakin.(along with your breakin lube.)
