Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - CAM Questions
Thread: CAM Questions
Old 07-02-2012, 10:32 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
That cam is a copy replacement for the L-82 350 motor cam. (245HP)
Its the same lame GM cam that comes in the lame 350-290hp GM crate motor.
no power and no torque.
It was lame in 350's and is lame in your 327.
And changing to a 1.6 rocker will not fix that.
Your money is much better spent on a better more modern hyd cam and lifters.
Keep the 1.5 rockers. They are fine.
You will notice a big performance difference with a different well selected hi perf cam in your 327.
lobe lift x rocker arm ratio ='s lift at the valve.
1.50 VS 1.60 ratio multiply the valve lift by 1.0666
EG: .450 x 1.0666 ='s .4799
New cam:
Crane Z-268-2 Crane #113521
http://www.summitracing.com/parts/CRN-113521/
Another nice choice
summit racing cam # SUM-1788
http://www.summitracing.com/parts/SUM-1788/
Here is a nice Howards hyd cam for your 327
http://www.summitracing.com/parts/HRS-110951-08/
All these will out perform the cam you got, reguardless of what rocker ratio you use.
www.cranecams.com
cams have come a long way since 1968.
