Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - CAM Questions
Thread: CAM Questions
Old 07-04-2012, 07:03 AM
ap72 ap72 is offline
Banned
A lot of people don't want gears because they get worried about buzzing down the interstate near 3,000 rpm. A 327 well built will buzz along happily at 3,000 rpm all day long. It also puts you closer to your tq peak so you'll be able to use the power you already have. Gears are probably the single most significant change you can make for performance, except maybe boosting the engine. You won't believe the difference. Build your engine to run between 0-5500 rpm, the gear it to put you in the middle of that power band when you cruise, it makes for one FUN street machine that is so easy and reliable my grandma could drive it.
