cam questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-22-2005, 10:15 AM
cam questions
Since I have been off of my round the world trip courtesy of the us navy I have ordered a 400sbc from a place called engine warehouse..costs me just over $1700.00 with a rv cam and getting the motor to my door. The cam that they put into this seems a little big to me and other guys I have talked to BUT I know nothing about cams at all so thought maybe yall could help me out.
Part # Elgin pro stock E-921-P
Valve lift: int 450 ext 460
Lobe Lift: int 114 ext 114
Sae Dur: 292 int 288 ext
.050 Dur: 224 int 224 exh
I will be running an auto trans, headers, 750 carb and the car will be street driven mostly. Thanks allot
Old 08-22-2005, 03:45 PM
johnsongrass1's Avatar
Race it, Don't rice it!
A slight stall with a tad bit o gear and she'll fly.
Old 08-22-2005, 03:58 PM
That will not be too big of a cam for a 400 with 9 to 9.5:1 compression. I think it will work fine for you. We have run up to 230 duration in 400's for snow plowing and off road work with no negative issues. If you do have concerns feel free to give Dema a call at Elgin, he is a very, very nice guy. The number is (650) 364-2187.
Old 08-22-2005, 06:09 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
With stock heads, intake, and rebuilder pistons that cam is perfect. You will not require stall with any cam under .488 lift. My 400 uses 302 deg duration but it's quite lumpy.
Old 08-22-2005, 09:28 PM
lluciano77's Avatar
I have an SBC 400. My cam has 234o duration and .520" (with 1.6 rockers) and a 114o lobe. It idles at 16" of vacuum and has killer throttle response.
Old 08-23-2005, 08:34 AM
cam
Thanks for all the info...
everything I was hearing around town I was kinda worried that the cam was way to big. We finally have the motor all in and ready to go, this morning we should be able to get it started and go have fun
'74 Corvette 454 dyno results- Comp Cam XE 274H questions Bob Turner Engine 12 05-19-2005 11:59 AM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 12:51 PM
More cam questions bamacj Engine 5 12-30-2003 07:34 PM
Stock crate 350 (Cam Questions) Savage64chevy Engine 3 01-21-2003 01:34 PM
cam and stall converter questions dk01_99 Engine 10 01-03-2003 11:57 PM
