Cam Questions, info - Hot Rod Forum : Hotrodders Bulletin Board
View Poll Results: How Good is the Info?
The cam book of truth is on my computer screen. 0 0%
It's about 80% true. 0 0%
I dunno/sort of relevant/undecided 0 0%
Total BS 0 0%
Voters: 0. You may not vote on this poll
Old 04-20-2006, 08:42 PM
ChevelleSS_LS6's Avatar
Jeep XJ and a Javelin
Last wiki edit: Compression test
Last journal entry: August 9, part III
Wiki Edits: 7
Cam Questions, info
I found the following in a performance related email newsletter and am asking for your input and what you think about it... -matt
Picking the Right Camshaft
What needs to be decided and in what order:
1. Lobe Family - This is a group of lobes that have
similar open/close ramps, but different durations. I
truly believe the smartest thing Comp Cams every did
was publish lobe specs in the back of their catalog -
it instantly made me a fan.
2. Intake Duration - If I had never run a Spin-Tron
this would be my number one. Get intake duration and
lobe family correct and you're 90% there.
3. Exhaust Duration - This maybe number three on the
list, but is actually a long way from the importance of
the first two.
4. Lobe Separation - Take every lobe separation you've
ever seen run with your application, place them on a
dart board, close your eyes and throw. That's how
relatively important this spec is.
Before I continue I want to talk about something I've
noticed on most message boards - whenever someone
mentions that something is not important, they are
immediately hammered with "Yes it is!!!" Don't let
these people stop you from practicing the 80/20
principle.
Questions that need to be answered:
* Engine Size - Use to pick durations.
* RPM Range - Use to pick durations.
* Rocker Ratio - Use to pick lobe family.
* Valvetrain Weight - Use to pick lobe family.
* Valve Springs - Use to pick lobe family.
* Exhaust Flow - Use to finalize exhaust duration
Questions that only need to be answered when you're
trying to look smart:
* Cylinder Heads
* Runner CCs
* Intake Manifold
* Compression
* Valve Size
* Header Size
* And on and on and on...
Old 04-20-2006, 09:55 PM
Siggy_Freud's Avatar
I am not going to fully dive into this discussion, but I can tell you the difference lobe seperation makes while tuning an ECM for a new cam. Go over to corvetteforum or thirdgen.org's forum and ask them what they think about lobe seperation and how it affects idling and tuneability.
Bringing history and technology together.
Need cam info Overdriv Engine 1 01-31-2006 01:40 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
305 cam carb manifold stickshift Engine 6 04-12-2005 03:46 PM
cam questions leftoverchrisac Engine 1 12-31-2003 10:03 AM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
