Cam recommendation? - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-04-2006, 03:15 AM
Nova66's Avatar
Cam recommendation?
BBC 540 Stroker, Brodix BB-2x Heads max lift .700
Need good torque 4500-7000rpm (drag race use)
Can someone recommend cam for this combination
Thanks
Old 09-05-2006, 01:20 AM
327NUT's Avatar
Theres a lot of cams, to get the cam you need I,d call Comp cams and they will ask you all the necessary info about your engine and car so they can make a recommendation.
Old 09-05-2006, 01:28 AM
Nova66's Avatar
Ok, I ask Comp cams then..
Pontiac cam? Wmarden Engine 12 08-22-2010 08:09 AM
Is it possible to degree an unknown cam? Scrumgees Engine 4 03-18-2006 11:50 AM
87 octane engine cam swap? 71C10 Engine 6 01-20-2006 10:50 PM
Help Me Pick A Cam Canadian Charlie Engine 2 11-16-2005 01:11 PM
More issues....lets talk cam failure TurboS10 Engine 23 09-28-2004 11:51 AM
