Cam recommendations
Hey i have a .040 350
9.1 comp 750 holley performer rpm stock heads mild bowl work 4.10 gears 4spd weight 3800 I called up comp cams and asked them for a cam recommendation for this setup and he told me to go with the xe274 cam .487 .490 lift 230/236 duration Do you think i should go with this cam or do you think i should go to something alittle smaller like the xe268 or the magnum 280, this is going to be used on the street so i dont want something to big i can live with a lopey idle. |
110 lobe separation
Yeah Nairb its a 4spd granny low thanks for the suggestion |
My experience has been that the technical advice offered by most of the major cam manufacturers is very accurate, especially with regard to cam selection. Have used Crower, Crane, Comp, Isky and Sig Erson selection advice. One thing to remember is that you are going to get much better advice if you will submit your engine details to the cam grinder via mail or fax, using the form that is in their catalog. Make a copy of the form, fill it out and fax to them. This way they are able to give your inquiry more time than they are able to during a phone call. This is especially true if anything in your application is unusual, or if the vehicle is specifically used for racing only.
