Cam recommended for my blown 327 SBC... - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-21-2009, 07:19 PM
I have recently ordered a new Wieand 142 supercharger for my 1968 327 Chevy that is in my custom 1949 Chevy pickup.
I already have been running a newly rebuilt 327 with steel crank, Hyper flat top pistons 9:2-1 comp, Scat H rods, Edel Performer RPM heads, MSD ignition, and am taking off the Edel performer intake and 600 Edel carb, and Comp cam Extreme series #CCA-12-238-2 (Summit#) Duration 262/270, Lift 462/469 to run the blower.
Now I am driving this pickup back and forth to work a lot and around town and I love the Low and Mid torque power. So the tech at Wieand set me up with a supercharger Holley 750 special carb (these mini-blowers run one carb) and now I need a cam?
Has anybody had any SBC's with a blower that could recommend a cam that would give me a great mid and low but really gives me big power with my set-up???
Old 01-21-2009, 07:25 PM
Banned
no cam will give you great low and high end power- there's a compromise. Figure out what kind of compromise you can deal with and that will help decide what cam you would like.
Old 01-21-2009, 07:43 PM
Everything is HAMMER!
Anyway you go with your cam make sure that it's a roller. Flat tappet cams are quickly becoming old news,and old scrap(swiping lobes). Just remember the higher lift on a flat tappet cam the sooner it will wear out, and nobody likes that.
Old 01-21-2009, 08:00 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
There's not a lot of compromise with a blower on the bottom end, even a 142, you'll have that bottom end torque.
Semper Fi
Old 01-21-2009, 08:01 PM
i was running a comp nx268h on mine pulled great from idle to just above 6000
Old 01-21-2009, 08:02 PM
Blower cam for 327
I'm sorry I thought I made that statement in my article that I want great Low and Mid range torque. This is definitely not a upstairs pickup. Maybe that will help as I'm just curious to see the suggestions as everybody's are different. I would really like to talk to somebody who has a similar set-up that way I know it's not just BS.
Old 01-21-2009, 08:33 PM
Banned
Well, in general, you'll want a dual pattern on a wider LSA, and you don't need to install it with as much advance. The duration is going to give you your power range. Anything over 230 will be mostly upstairs, anything below 210 will be mostly down low. Here's a nitrous grind from summit, http://store.summitracing.com/partde...4&autoview=sku
It'd work pretty well, not saying its the best, but it gives you an idea of what you're looking at. That is if you use hyd. flat tappet, which I'm assuming you are.
Old 01-21-2009, 09:11 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
If you can afford a retro roller, do it. I'm running a Lunati 282/290, 112 lsa that's a killer off idle all the way up. That blower is going to give you increased bottom end, trust me.
Semper Fi
Old 01-22-2009, 07:46 AM
could use the cam that you have. However, can't run much boost with that cr. maybe 5 or 6 psi with a bunch of timing retard (maybe 20 degrees total advance while on boost with 93 octane). Do you have a msd boost timing retard??
if you would install a bigger cam, 270 intake with 280 exhaust ground on 114 lsa, then you could run a few more psi of boost and a few more degrees of timing.
9.2:1 is high cr for a boosted 1st gen sbc with a little cam.
Old 01-22-2009, 08:23 PM
cam for my 327 and Wieand blower...
You guys are great and very knowledgeable! Thanks.
I'm not sure what you mean on the advance retard for sure but it is a new all billet MSD set up. I am aware of the compression thing but I just would hate to pull it all down and replace pistons etc. It was hard enough to find a set of Hyper KB pistons for a 327 anyway. I guess I'm just too obsolete?
I would like to just run about 5 psi boost with what I have now and see what happens I think and if I want more I can do the cam and if that still don't I can do a change of some type pistons. It's .030 pistons now and we filled them for NOS that I don't have but that is the same thing they do for superchargers too.
This is my question: Is there a device or anything that I can use or install that will tell me how my engine is doing and if it is detonating any at all? I know the plug reading thing and the ping or knock but I'm afraid I wouldn't hear that so I wonder if there is some cool electronic thing that will do some king of analysis or readout of whats going on with my fuel and air, heat, detonation that anybody knows about?
Old 01-22-2009, 09:06 PM
you could possibly install a knock sensor... I'm not sure if there is a way to set it up to work right, you will have to research a little... but GTech may have your answer. I've been considering buying one, but I haven't heard too much about them in the hotrod community. If anyone has any experience with them in our older rides let me know, all I've seen them in is new muscle (Mustangs, Camaros, and Chargers) and rice.
Old 01-22-2009, 10:37 PM
scares me a bit
your combo did i hear ya mention hiperkenkic pistons ? hope not with a blower - ya will picken ringlands out of oil pan next - as far a cam stay mild for that bottom end - lower compression and use blower boost for mid and top and it will live , also run a GOOD ignation box hook it up to a pressure sensor to retard on boost simular to the nos stuff - want MORE later add nos
Old 01-22-2009, 10:51 PM
dawg's Avatar
NAVY VETERAN
ive had friend use a comp cams blower cam for smaller displacement motors
here it is here
Old 01-24-2009, 05:55 PM
pm replied
Pick my cam for my blown sbc 350....shooting for 700ish horse darkostoj Engine 11 11-05-2008 12:17 PM
SBC Solid Cam, Rockers Hitting Valve Covers?! ezobens Engine 11 05-01-2007 01:24 PM
SBC cam for the street, hydrulic or soild lift tiresmoke55 Engine 19 09-01-2006 10:22 PM
New cam engle ep-22 will it work in a mild 327 Mr. Wormy Engine 2 08-09-2006 08:08 PM
chevy head and cam suggestion needed for 327 Berliner Bel Air Engine 3 12-06-2004 09:44 AM
