Anyone with a rule of thumb for Maximum lift without connecting rod interference in a Small Block 383?
were running a roller cam close to .700 lift. small base circle cam
I run a .640 solid roller in mine w/ a .900 base circle. No problems.
Strkr |
I will have to mock the cam up. I will be running a comp cam roller cam with .520/540 lift. In the mock up process would it be easier simply to first install each piston separately and rotate the assembly through 720 degrees or several revolution to see if something is in the way. Measuring cam to connecting rod clearances may be difficult. Visual is about all you have unless you actually contact the two in rotating the assembly. How much clearance is acceptable? Thanks for all your assistance
Sam [ October 16, 2002: Message edited by: Cobracar ]</p> |
