ok thanks from what i have been reading that seems like it will be a good cam for the motor. I dont wanna get to radical of cam were i have to many problems but i want something that sounds and performs decent. do you think this will be my best bet along with iskys ani pump up lifters. i dont use the truck as a truck just want something that i can have fun in and get back and forth to work with. i have a 3,000 stall in trucjk now
26deg inital base idle timing, 36 total max mechanical at 3000-3200 (limit the distributor advance travel to 10-12deg .....10-15deg vacuum advance for cruising. The truck will want high ratio gears 4.10+ with the 278 mega. search Dencouch 's posts for the hows and whys. The smaller 264d cam will get better fuel mileage. |
I may be wrong here, but I believe a lumpy sounding cam gives better high end and a smoother cam gives better low end torque.
What's your preference other than sound? |
I want performance the trucks a daily driver I want to sound good buy want it to be reliable to i want the biggest cam
I can without having to replace springs and worry about breaking thing s |
Elgin makes a cam with 274/274 duration and .450/.450 lift on a 106 LSA and a 102 ICL. It works very well with a 3,000 stall and is very mild. Has killer mid range torque too, BUT milage is not the greatest. People have swapped it into otherwise stock engines with headers and have had good results. You need a good exhaust system with it though.
http://www.youtube.com/watch?v=LLWKKG1REXQ
Its the elgin cam I was talking about, its the one that comes in a Comp box labeled 274h06, but its the same cam, all the cam manufactures sell a version of this cam. Elgin just has the best price. |
that cam, the Isky 278Mega, will actaully have an even more radical idle and will nto work with a stock converter as F'bird already noted. It will give you mpore hp up top, but sacrifice some low end power. Not a bad cam if you build the rest of the truck to suit it. For an otherwise stock truck though the cam I showed you is as large as I would go.
http://www.competitionproducts.com/E...tinfo/E1785PM/
E1785P is part number for that cam i recomended. Works fine with "z28" springs. |
Here's a video link to the sound of the isky 278 cam. Well, from inside but you get the idea of how choppy it sounds.
http://s185.photobucket.com/albums/x...-bird88vid.flv |
| 350 sbc Shortblock and vortec heads | 1970Chevy | Engine | 2 | 09-23-2007 04:21 AM |
| Motorheads...Need help with Vortec style heads, can they just be swapped? | firstgear | Engine | 16 | 01-15-2007 12:02 AM |
| Vortec heads w/solid lift cam...anyone? | rbomar | Engine | 6 | 08-25-2006 04:42 PM |
| cam selection for sbc w/ efi and e-tec 200 heads? | c10redneck | Engine | 0 | 07-18-2005 12:48 PM |
| Holley fuel injection with Vortec heads onna SBC. | Pappy | Engine | 3 | 06-06-2002 11:17 AM |
