cam scrapes rod bolt - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-28-2003, 12:27 PM
Post cam scrapes rod bolt
I am building a409 small chevy,I have just put the cam in,solid roller with .640 lift, when I rotate the assembly, the cam hits the head of the rod bolts, the book calls for .050 thous. clearence. Can I grind that much off each bolt?
Old 03-28-2003, 12:34 PM
DoubleVision's Avatar
Post
you`ll have to, it calls for that much due to expansion after it gets hot, if you don`t have anything to measure the clearance after grinding, get a coat hanger and measure it`s thickness, then you should be able to flex it to get it between the bolt and the lobe to check the clearence.
