Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam selection
Thread: Cam selection
Old 11-30-2012, 07:45 PM
kentactic kentactic is offline
Originally Posted by vinniekq2 View Post
I use big cams in my cars,
for you maybe something like this
110173-10S NA 273 279 241 247 .570 .570 110 106 .022 .022 1,2,5
2800-7000 Small Base Circle, Fair idle, High performance Street/Mild Bracket. 10.0:1 CR, 2800+.
Ok now the heads im running says its for flat tappet. Wont work no?
This cam is flat tappet and although this cam dosent have a recommended compression the one next size up says 11:1 or more so perhaps this one being one level less will work on 10.5:1 ? Im liking the RPM range.
Sbc Solid Tappet Chevy 350 383 Camshaft Kit 290/300 Gm - KMJ Performance
EDIT: Now im not seeing that they are for a flat tappet lifter so the heads work either way?
