Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam selection
Thread: Cam selection
  #18 (permalink)
Old 11-30-2012, 09:54 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by kentactic View Post
Ok thanks for the input. Ill add this car wont be driven to the track. always trailered.
Ok so that makes a big difference cause the next larger cams will still be bumping at 2k rpm. You can go with the largest flat solid magnum or xtreme.
The largest magnum is about as large as i would go. Xtreme from comp is in the same range for the largest cam. Xs290s is flat solid as well
Magnum 306S
12-225-4 - Magnum
What type of trans?
