Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam selection
Thread: Cam selection
  #20 (permalink)
Old 11-30-2012, 08:57 PM
kentactic kentactic is offline
Originally Posted by hcompton View Post
Ok so that makes a big difference cause the next larger cams will still be bumping at 2k rpm. You can go with the largest flat solid magnum or xtreme.
The largest magnum is about as large as i would go. Xtreme from comp is in the same range for the largest cam. Xs290s is flat solid as well
Magnum 306S
12-225-4 - Magnum
What type of trans?
Now were cookin! Im really not as far as the trans. Ive heard turbo 350 a lot. It says the springs must be modified. The assault heads dual springs are good to go for that right? It also says the heads must be machined. The assault heads are good to .650" lift so theyll work as is correct?
