Originally Posted by kentactic
Ok thanks for the input. Ill add this car wont be driven to the track. always trailered.
I ran 5.90 in the 1/8th with a 410 cu in Windsor in a 92 Mustang. This car had 12 to 1, heads that flowed 360 cfm intake, a solid roller .700 lift cam and a 500 shot of 2 stage fogger nitrous throu a JW powerglide and 4.10 gears.
This is just to give you an idea where you have to go to run 5s in the 1/8th.
Get a copy of desktop dyno so you can run the combinations of compression, cam, power adders so you don't waste money on components that won't get you where you want to go.
Set a goal of how quick you can afford to go, then build it! Have fun.
