Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Cam Selection 292h or XE284 .
Old 12-20-2012, 07:54 AM
stackitup_91 stackitup_91 is offline
I am in the process of doing a SBC build it's a Chevrolet 350 bored over .30, I have 2 valve relief Speed Pro pistons which puts me at 10 to 1 compression
as far as my cylinder heads go I have a set a vortecs with screw in studs ,new guide plates, and also new springs that can handle up to 550 lift.
I have an EdelBrock rpm air gap intake, 1 5/8 hooker headers (shorties),
I was going to use 1.5 ratio full roller rocker arms, my gear ratio is 3.73 the Motor will be going in a 84 z28 Camaro
I wanted your opinion on which cam I should go with the 292H comp cam, or the XE284 comp cam?, and I also wanted to know whether the 1.6 ratio rocker arms will help me? my goal is to get at least 325 horsepower to the wheels..
