Cam selection on 347 stroker - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-15-2012, 01:41 PM
abrush's Avatar
Just picked up a 347 stroker shortblock with Mahle flat top pistons, eagle rods and scat crank. I have a brand new set of Edelbrock Victor jr. aluminum heads I plan to install. This motor will be going in my 65 Mustang show car as I would like to upgrade the 289 for something a little more fun. I need to select a cam for this engine but am unsure what would suit it best. The car has a Toploader 4 speed manual tranny and 3.00 rear end gears. I want to keep this car streetable as I drive it every weekend to a show in the summer and occasionally see interstate travel of 70 mph. The car will never be pushed past 6500 rpms. I also would like to ensure adequate valve to piston clearance. Suggestions?????
Old 10-15-2012, 04:27 PM
vinniekq2's Avatar
use a short duration hydraulic roller.
Old 10-15-2012, 06:23 PM
Irelands child's Avatar
Just choose one of Ford Racing's 'letter' roller camshafts. Reasonably priced, decent performance and easily available. Match with a set of roller rockers and you will have all the camshaft you will ever need for a street driver. I'm using the 'E' now - very nice, with good in town manners :
http://www.fordracingparts.com/downl...shaftSpecs.pdf
Irelands child
Old 10-16-2012, 07:29 AM
abrush's Avatar
Thanks I have actually looked at a couple of those Ford Racing cams. Would one be better suited towards my build? Also what lifters are recommended with them?
Old 10-16-2012, 08:09 AM
With the 3.00 gears and the 4spd (I assume)top loader, I would probably stay with the 'E' camshaft and use the stock Ford roller lifters. Now, if this is not a roller block, then you get into aftermarket roller lifters and then might want to consider Comp Cams. Yes, there are literally dozens of cam grinders out in the market place, but those key words you are using - 'streetable' and 'interstate driving' make for, IMO, fewer choices as every one of the smaller companies seem to want to sell you a race geared cam. If, for instance, you have a flat tappet engine, then an Edelbrock Performer RPM is always a pretty good choice, especially when paired up with the Performer RPM intake.
Irelands child
Old 10-16-2012, 12:55 PM
techinspector1's Avatar
Wiki Edits: 326
Only way to insure clearance is to measure clearance in your mock-up pre-assembly build. Each motor is a stand-alone set of circumstances and nobody can tell you, out of thin air, that you will or will not have piston to valve interference. Some of the variables are:
Block deck height
Piston deck height
Piston compression height
Piston crown configuration
Camshaft lobe profile (most often, interference occurs at the exhaust valve during the last few degrees of overlap period when the piston is coming up the bore and chasing the exhaust valve back onto its seat).
ACTUAL rocker arm ratio
Diameter of valves
Distance from valve seat to deck of head
I would also bring "squish" to your attention. This is the piston deck height added to the head gasket thickness and determines the effectiveness of the parts to effect a squishing or jetting of the air fuel mixture out from between the piston crown and the underside of the cylinder head. This turbulence helps to homogenize the mixture and eliminate rich and lean pockets in the chamber just as the spark plug fires. The motor will like a good tight squish which is just short of a piston/head collision with everything at operating temperature and max rpm's.
496 stroker cam selection hotboy454 Engine 1 07-21-2011 05:14 PM
347 Stroker Xtang Engine 9 06-22-2010 09:07 AM
347 stroker erythnul Engine 8 05-07-2005 10:59 AM
347 Stroker Silentlion_69 Engine 1 09-08-2004 08:45 AM
347 Stroker nightrain_rod Engine 2 05-18-2003 06:40 PM
