-   -   Cam selection on a 383 build (http://www.hotrodders.com/forum/cam-selection-383-build-49282.html)
TCAMARO 10-07-2004 11:08 AM
Here is what I will have:
Holley 650DP
RPM Air gap intake
AFR 195cc heads milled to 64.1cc
Hooker 1 3/4" headers
Muncie M20 4sp
4:10 gears
26" tall tire
all in a 383.
Want to maintain enough vacuum for power brakes etc.....
Car is a weekend cruiser, sometimes take on trips. Want to get as much out of it as possible.
What is your recomendation?
jo5hi3 10-07-2004 02:15 PM
hey man i have a 383 setup and i have the comp cams xe274h and i really like it. its a good all around cam
brainsboy 10-07-2004 02:23 PM
If you plan on road trips the 4:10's with 26" tires may be a little low. For power the 650 seems small, but would do fine for road trips. As far as cams, Im sure you will get a few opinions, If its in your budget I would try something in a hydaulic roller, most are very streetable and make plenty of power.
Ben
firestone 10-07-2004 02:33 PM
If you wanted a hydraulic flat tappet cam, I would probably go with the 286H or the XE284H(this one would probably be a little better with vaccum) both with a set of 1.6 rockers. If you wanted a hydraulic roller, I would recommend the XR288HR or the 286HR. All of these cams would perform around 2200 6200 in a 383 like you are building. They are extimated to have a slightly higher powerband than that, but that is based off of a 350. With a 383, the powerband will drop around 300 RPM, and the vaccum will increase over a 350 due to the cubic inches. If you want to check out the specs on these cams, the site is posted below.
Adam
http://www.compcams.com/Technical/Cu...ML/128-169.asp
killerformula 10-07-2004 02:36 PM
284 comps roller with a proper carb will get you on the high side of 500 horse.
K
MI2600 10-07-2004 02:55 PM
I'm currently running an L-79 (.222@.050 w .447 lift) that I saw in a Lingenfelder 383 build-up. It's just not cutting it. I'm going to switch to an XE274.
I've found that the 383 is wound about tight at 6000. The XE274 is advertised at 1800 to 5600.
TCAMARO 10-07-2004 07:26 PM
I paln on going with a Hydro. roller.
strikingthematch 10-07-2004 09:12 PM
Anyone think the comp. cams 280 magnum Flat hyd. is a good cam for a 383?
Gross Valve Lift 0.48 0.48
Duration At 0.006 Tappet Lift 280 280
Valve Timing At 0.006
Open Close
Intake 34 66
Exhaust 74 26
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 230 230
Lobe Lift 0.32 0.32
Lobe Separation 110
Or the 292
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.501 0.501
Duration At 0.006 Tappet Lift 292 292
Open Close
Intake 40 72
Exhaust 80 32
Intake Exhaust
Duration At 0.05 244 244
Lobe Lift 0.334 0.334
Lobe Separation 110
Just wondering as far as all around Tq and HP go. I was thinking about going with the 280 just because that one seemed to fit just what I wanted to do but I just wondered what anyone had to say. :thumbup:
Thanks
Chris
firestone 10-08-2004 10:37 AM
Striking, what are the other parts of your motor?
Adam
strikingthematch 10-08-2004 02:43 PM
SRP Flat top forged pistons making 9.7:1 with 76 CC in heads.
Moly Rings
AFR 195 Street ported heads. valves 2.02 intake and 1.6 exhuast
Comp. Magnum Rockers 1.5 or 1.6
Eld. Prof. intake
750 DP Holley
Hooker headers std. size
K&N air filter...
Hope thats what you needed.
Chris
