hey man i have a 383 setup and i have the comp cams xe274h and i really like it. its a good all around cam
If you plan on road trips the 4:10's with 26" tires may be a little low. For power the 650 seems small, but would do fine for road trips. As far as cams, Im sure you will get a few opinions, If its in your budget I would try something in a hydaulic roller, most are very streetable and make plenty of power.
Ben |
If you wanted a hydraulic flat tappet cam, I would probably go with the 286H or the XE284H(this one would probably be a little better with vaccum) both with a set of 1.6 rockers. If you wanted a hydraulic roller, I would recommend the XR288HR or the 286HR. All of these cams would perform around 2200 6200 in a 383 like you are building. They are extimated to have a slightly higher powerband than that, but that is based off of a 350. With a 383, the powerband will drop around 300 RPM, and the vaccum will increase over a 350 due to the cubic inches. If you want to check out the specs on these cams, the site is posted below.
Adam http://www.compcams.com/Technical/Cu...ML/128-169.asp |
284 comps roller with a proper carb will get you on the high side of 500 horse.
K |
I'm currently running an L-79 (.222@.050 w .447 lift) that I saw in a Lingenfelder 383 build-up. It's just not cutting it. I'm going to switch to an XE274.
I've found that the 383 is wound about tight at 6000. The XE274 is advertised at 1800 to 5600. |
Anyone think the comp. cams 280 magnum Flat hyd. is a good cam for a 383?
Gross Valve Lift 0.48 0.48 Duration At 0.006 Tappet Lift 280 280 -------------------------------------------------------------------------------- Valve Timing At 0.006 Open Close Intake 34 66 Exhaust 74 26 -------------------------------------------------------------------------------- These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 230 230 Lobe Lift 0.32 0.32 Lobe Separation 110 Or the 292 Intake Exhaust Valve Adjustment 0 0 Gross Valve Lift 0.501 0.501 Duration At 0.006 Tappet Lift 292 292 -------------------------------------------------------------------------------- Valve Timing At 0.006 Open Close Intake 40 72 Exhaust 80 32 -------------------------------------------------------------------------------- These Specs Are For The Cam Installed At 106 Intake CL Intake Exhaust Duration At 0.05 244 244 Lobe Lift 0.334 0.334 Lobe Separation 110 Just wondering as far as all around Tq and HP go. I was thinking about going with the 280 just because that one seemed to fit just what I wanted to do but I just wondered what anyone had to say. Thanks Chris |
SRP Flat top forged pistons making 9.7:1 with 76 CC in heads.
Moly Rings AFR 195 Street ported heads. valves 2.02 intake and 1.6 exhuast Comp. Magnum Rockers 1.5 or 1.6 Eld. Prof. intake 750 DP Holley Hooker headers std. size K&N air filter... Hope thats what you needed. Chris |
