Cam selection... 383 chevy, vortechs, heavy car...streetable but fun. 400hp-ish - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 12-04-2012, 04:28 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
Not going to take away anything from a Howards roller,nor from Edelbrock.But your comparing apples to oranges Ap.
  #17 (permalink)
Old 12-04-2012, 05:21 PM
Motochris's Avatar
Originally Posted by hcompton View Post
Not sure how you can say that edelbrock is the one company out there that really stands behind there product. They sell the highest quaility hop up parts on the market. Yes they focus on middle of the road performance. But that hardly means its junk. Really means its what this car needs.
With this car i would go for 300-350 ft tq. Hp is not going to matter much and may even slow the car down if the cam is to peaky. I got my 4000 pound 71 gp from a guy that had tried 10 cams and finally went with a smaller pmd cam factory cam. That made the car run the fastest at the track. The op can save himself the issues of replacing several cams to find something that works he could just get the performer or the torker. Edelbrock provides thecombos that work for little money and big results that act as expected.
The 59 wagon has to be every bit of 5000 lbs. Does it have an X frame? Might want to be easy on it with older frame. 400hp and the tq that comes with it is a lot of pressure to put on the old style frame. It will be fine with street tires and normal fun run type of driving. Some slicks and some abuse at the race track could lead to some major issues. Best to let it spin if you get a lot more power than stock. Especially if it has stock suspension and brakes.
This car will NEVER see slicks.
It's in the parking lot here at work right now. It's my daily driver, I just want it to be fun. If it doesn't have 400hp... that's OK, I just had to make a target somewhere. I want it to run good, be a hotrod. The current setup has all the parts listed in my first post in a 350 with a very mild cam...it needs more oomph....
ID:	69585   Click image for larger version
  #18 (permalink)
Old 12-09-2012, 06:48 PM
Motochris,
You never said if the vortecs were modified from stock to allow more than 0.450" valve lift.
If they have you may want to consider the Comp Cams 270HR. Using their Camquest software configured for your combination it indicated 404 HP and 463ftlbs of torque, 218*@0.050" lift single pattern cam, 0.500" valve lift with 1.5:1 rockers. Should work good with your torque convertor.JMO
You may want to upgrade your valve springs for insurance.JMO
ssmonty
  #19 (permalink)
Old 12-09-2012, 07:00 PM
Motochris,
You never said if your vortecs were modified for more than 0.450" valve lift.
If they have you may want to consider a Comp Cams 270HR roller cam with 218* duration @0.050" lift single pattern, w/.500" valve lift w/1.5:1 ratio rockers. Using Comp's Camquest software with your engine specs it indicates 404HP, and 463ftlbs of torque. You can get a few more rpm with the XR270HR to get 411HP and the same 463ftlbs with a slight loss of torque off idle.
Both should work good with your torque converter IMO. You may want to upgrade your valve springs.
FWIW,
ssmonty
  #20 (permalink)
Old 12-13-2012, 04:30 PM
Motochris's Avatar
Originally Posted by ssmonty View Post
Motochris,
FWIW,
ssmonty
Thanks. I was looking at that exact cam (270HR) too. My heads are NOT currently setup for the higher lift, but I'm leaning that way. May as well do it while it's apart.
  #21 (permalink)
Old 12-13-2012, 04:42 PM
hcompton's Avatar
Old & Furious
The most expensive words in hot rodding are "might as well"
383 Cam Swap. Thoughts? More Streetable... V8 Super Beetle Engine 35 10-26-2012 01:28 PM
Help with cam selection on my 383 ags111075 Engine 1 10-08-2009 10:15 PM
Cam selection for Vortec Chevy 383 mytruckownsit Engine 7 06-14-2006 08:16 AM
Roller Cam worth the extra bucks for SBC 383 making like 400hp?? 89SDime Engine 10 03-11-2006 03:22 PM
Cam selection on a 383 build TCAMARO Engine 9 10-08-2004 03:43 PM
